Need some advice....it just wont hook!! - Kawasaki ZX-10R.net
post #1 of 9 Old 07-05-2011, 06:04 AM Thread Starter
ke2012's Avatar
Good morning all,
Having some issues with my set up....havent had a clean pass yet, due to not being able to get my bike to hook....every pass i either spin off the line or spin when i pin it right around the tree. Track is pretty well prepped, spinnning is not an issue generally. I have 3g is @ 64, geared 15/43 got a busa shock 3/4 clicks on, on compression and dampening, running a power one at @ 18 psi. When i sit on the bike swing arm is parrelell to the ground and the bike squats just as it should. Ive tried a light burn out and a 5 alarm smoke infested burnout....at some point before the 60ft ..every pass, i have lit up the tire Should i try running compression and rebound all out(counter clockwise until stop)?? Or, with the power one, im considering getting a hookup thinking it may not be a suspension issue at all but a tire issue. Or maybe my clutch hand sucks.....
Despite the spinning issues im happy as hell with the bike, running horrid 60fts 1.90's:headshake, my bike when it hooks...GETS IT....1/8TH 112-116 and 1/4 144-146...so the bike is straight i just need to ride the thing....thanks in advance for any advice.
ke2012 is offline
post #2 of 9 Old 07-05-2011, 08:21 AM
codyc_13's Avatar
It sounds like its starting to hook on you and then unloading the shock causing you to spin. I would try adjusting the rebound to where it rebounds slower.
I have had great luck with shinko, but I've also heard the power one is an excellent tire also.
Sponsored by:
Vaughan Racing
Synthetic Shield
Moline Bar
codyc_13 is offline
post #3 of 9 Old 07-05-2011, 09:02 AM
quikgix's Avatar
Bring the rear tire pressure down to around 12-15psi.
Now what
quikgix is offline
post #4 of 9 Old 07-05-2011, 05:02 PM
gazx10's Avatar
what gix said, ive had to run tire pressure as low as 8 lbs to insure constant hook. keep dropping the tire, it will hook.
gazx10 is offline
post #5 of 9 Old 07-05-2011, 08:18 PM
fbmbks's Avatar
Send a message via AIM to fbmbks
I run 24 lbs in my hookup, prolly round 65 inches w 15 45 gearing and never have a problem looking, i would say its suspension, ur swingarm may be a hair low in the rear too
fbmbks is offline
post #6 of 9 Old 07-05-2011, 08:34 PM Thread Starter
ke2012's Avatar
definately appreciate all the input fellas...the plan at this point is to run @ 15lbls in the P1, drop the compression a few clicks and take the rebound to full soft. also i never mentioned but im 190lbs suited.
ke2012 is offline
post #7 of 9 Old 07-06-2011, 11:09 AM
gazx10's Avatar
drop it more 10-12 for a start.
gazx10 is offline
post #8 of 9 Old 07-09-2011, 05:39 AM Thread Starter
ke2012's Avatar
thanks again for all the advice fellas......
todays plan...12psi, compression 2 clicks from full soft, rebound full soft. Staging/launching at 6-8k, whack it from the gate....feather the clutch to the tree. If it doesnt hook today im ordering a hook up monday moring!!
ke2012 is offline
post #9 of 9 Old 07-09-2011, 06:19 AM
Send a message via Yahoo to noel10
good luck
noel10 is offline
Gen 3: Help, looking to hook up PCIII 10RRdy4U The ZX-10R 4 05-27-2011 01:57 AM
Ek zzz 520 & supersprox 44t...hook me up!!?? ke2012 Wanted: Buy or Trade 3 01-20-2011 08:54 PM
hook ups on the pvm white 20 spokes djr33 Vendors deals 1 11-18-2009 08:26 AM
anyone have a hook up on carrillos??? garth285 Vendors deals 3 11-02-2009 03:07 PM
So what's the hook? 26606 General Motorcycle Discussions 13 10-13-2009 07:02 AM
