Need setup help for better times - Kawasaki ZX-10R.net
post #1 of 3 Old 10-12-2010, 01:32 AM Thread Starter
BlkCasper's Avatar
Been going around on diffrent setups trying to get better times. Here's my current setup:
06 ZX10. strapped, lowered 3" in rear, stretched, appmx 61"-63" depending on what gears i'm running. Current gearing 16/42. All short stacks, k/n filter, all smog stuff renoved, gutted cats, shortnend dnd cans, custom tune apmx 186hp/82flbs tourque, dunlap sportmax Q2 tires stock sizes.
Issues:
SWB: leaving around 5k, bike boggs the runs good, best time of [email protected] 145 1/4 mile. best 60" of 1.68 - 1.72.
Streached: leaving around 7k-9k spinns half way through 60" ft best time 0f 10.1 @ 143 1/4 mile. best 60" 1.65 - 1.73 .
All passes just hitting 4th gear or topping out in 4th if i get a bad launch. Do i need more gearing???
Thinking i need to change rear tire to shinko u-soft. but money not there yet,
Thinking with current setup i should easily be running 9.6 - 9.8 1/4 mile. Any help or thoughts would be appreciated.
i know if i got the 60" fts down to around 1.4 - 1.6 i could run these numbers.
Biggest problem seems to be getting good 60" fts.
BlkCasper is offline
post #2 of 3 Old 10-12-2010, 11:17 AM
zx racer's Avatar
if the bike is bogin try a lil more rpms, i leave around 8 or 8.5 rpms when i leave the line on my swb 10. best 60 to date is a 1.60 60ft. ive not ran the 1/4 yet but i average between high 6.30's low 6.40's consistant. could try a lil more gearing to see if that might help ya but i would try raising your rpms 1st and see where your at.
05 ZX-10R SWB.
zx racer is offline
post #3 of 3 Old 10-13-2010, 03:15 PM
Send a message via AIM to Cycle Concepts
you need alot more gear...more like 45-46 in the rear...the zx10's all have very long first gears in them from the factory and they are horrible for dragracing...we as dragrace builders/tuners replace the factory first gear with an aftermarket low first gear so we can gear the bike better for dragracing...
Cycle Concepts is offline
new setup for my '05 10roller Pictures and Videos 6 06-26-2009 04:56 PM
SuperSport setup Spillman Strip 10 09-27-2008 10:39 AM
Nitrous setup Yogurt Performance and Tech 9 05-28-2007 09:14 PM
Suspension Setup DVD? Harper15 Performance and Tech 4 04-27-2007 02:30 PM
setup hairbear Welcome Newbies! 13 07-21-2006 06:12 AM
