Need a little guidance on lowering/stretching - Kawasaki ZX-10R.net
post #1 of 24 Old 06-28-2011, 02:04 PM Thread Starter
Hey whats going on guys?
Looking for a little direction for setting the bike up for some straightline stuff and general riding.
I am very new to the powersports stuff so forgive any ignorance
The bike is a Gen 1
-1 front
Full Arata System
Tuning and stacks coming soon
Also building a custom direct port nitrous setup to spray it until it makes 200hp.
What factors decide on what you need as far as stretching and lowering? Im looking at trying to figure out what I need to know to decide what level of lowering and stretch I need.
Does over all suspension setup Change it? Rider weight? Tire?
Or is it simple a question of how much power you make?
Trying to make an educated decision but I don't know where to start.
Thanks for any help guys!
post #2 of 24 Old 06-28-2011, 02:28 PM
09zx10miami's Avatar
I'm not lowered and I'm making 242hp on spray....but I only spray 4th -6th gear.... Otherwise the bike wants to come str8 up.....as far as lowering that's up to your personal preference ...the lower you go the less agile your bike will be...
****Giiiiiiiiittttttuuuurrrdooonnneee****
09zx10miami is offline
post #3 of 24 Old 06-28-2011, 02:34 PM Thread Starter
I have thought about really getting after it with some spray. I just dont know enough of what the gen 1 drive line will handle.
Are you stretched at all?
Im just curious what balance of lowering and stretching will get it stay hooked up and not facing the sun.
post #4 of 24 Old 06-28-2011, 04:38 PM
quikgix's Avatar
When I had my 05 10R i used a #34 jet dry shot spraying before the air filter
and it made 201 hp at the rear wheel. I still have a few custom maps from those days.
Now what
quikgix is offline
post #5 of 24 Old 06-28-2011, 04:53 PM Thread Starter
Awesome.
Where you lowered or stretched at all?
post #6 of 24 Old 06-28-2011, 04:57 PM
Certified SLOW
nolaZX10's Avatar
Are you building this for just drag racing or just the street as well? 1/4 mi or 1/8 mi?
Best 1/4mi ET: 8.98 @ 147 (stock motor, no turbo/nitrous)
nolaZX10 is offline
post #7 of 24 Old 06-28-2011, 05:15 PM
Supercharged Mod
I did a lower/stretch on my gen 1 to make it a better drag bike, but I still wanted to keep it streetable with acceptable steering and suspension characteristics. No nitrous, and no plans to.
Started with some math: wanted to be near the top of 5th gear at the end of a quarter mile, and with some estimates of what the trap speed ought to be, that led to the gearing selection. I prefer to do all the ratio changing with the rear sprocket. I ended up at 17/45 (stock is 17/39) and "actual field experience" has been that this seems about right. Keep in mind that not only is this no nitrous, but also no power adders at all. If you have major power adders then use a different estimate of trap speed, and you can always go through at the top of 6th rather than 5th, crunch the numbers.
Now some estimating: 17/45 ought to accelerate about 15% harder than 17/39 (45 divided by 39).
To compensate, we need to make the bike 15% less "wheelie-prone" and a bit more for good measure. If the center of gravity height stays the same height then the distance (in the fore/aft direction) between the center of gravity and the tire contact patch needs to be 15% more (plus a bit more, just to make sure). The C of G of the combined rider and bike is a little rearward of halfway between the front and rear wheels (i.e. about 26ish inches ahead of the stock rear wheel contact patch). Add 15% to get it to where we want it to be and it sounds like a 4 inch stretch. My target was 5 1/2 inches and this is without any lowering.
If you have major power adders that result in the engine making more torque than stock then it needs to be factored in just like the above.
If you want decent steering characteristics for normal road riding then lowering needs to be minimized and you need to keep suspension travel (including the sag measurement) in a normal range. In particular, with the front suspension at full compression, the front fender must not collide with the upper fairing or radiator. If you want to maintain full suspension travel then this sets a boundary on the amount you can lower the bike, and it isn't very much! 10 millimeters or thereabouts. That's what I did.
Now it gets tricky; you need to set nominal rear ride height such that it keeps the rake and trail in the same range as stock. The down-angle of the swingarm will raise the rear if you just extend the swingarm, so you need lowering links - in combination with ride-height shims.
I used swingarm extensions, fixed-length lowering links (I seem to recall that they give about 2" lowering if installed without doing anything else), 190/55 rear tire, and some washers under the upper shock mount to fine tune the rear ride height. Initially I used three 1/8" thick washers but I'm now at two 1/8" and one 1/16" washers - I fine tuned this based on how the steering felt.
It took some fiddling with ride-height washers and spring preload to get it worked out but I'm happy with the end result. Steering feel during normal riding is almost normal; it's a wee bit slower/heavier than standard but it's not a bother. Cornering clearance is still good (because it's only lowered by about 10mm ...), suspension compliance seems same as stock (because full compression and rebound travel is available), it doesn't bottom on bumps any more so than it did when stock, and there is still at least *some* swingarm down-angle to give at least *some* anti-squat geometry. And the front fender won't collide with anything, and the suspension will hit mechanical limit before the oil drain plug smacks the ground ... it probably has enough ground clearance to drive off a normal kerb, although I'm not about to try it (again, it's only lowered 10 mm).
It is never going to have as much grip exiting corners as a stock-wheelbase bike. But for a street ridden bike ... it's fine and is actually a silly fun street bike, because the shorter gearing lets the engine get into the power band at sane road speeds ... and because it doesn't steer like a school bus.
A bike with more extreme power adders will need more stretch and/or more lowering ... and more rear tire grip to avoid spinning the tire on takeoff.
GoFaster is offline
post #8 of 24 Old 06-28-2011, 05:17 PM Thread Starter
Both. No track days (road racing) for me, but I just don't want to kill the overall feel of the bike to be ruined.
No set length on the track. I will probably re-gear for some of the longer events.
post #9 of 24 Old 06-28-2011, 05:19 PM Thread Starter
Great Post. Thanks much for such a response. I will definitely keep this in mind as I weigh out the options. It sounds like we both had similar ideas about how we wanted the bike to perform.
post #10 of 24 Old 06-28-2011, 07:45 PM
quikgix's Avatar
I lowered it with 3 hole links in the lowest setting, then lowered the front end about 1-1/2 and used a strap to pull it down til it almost hits the top of the fender. And the bike was at around 65" wb
Now what
quikgix is offline
stretching and lowering 2005 zx10 frizzle The ZX-10R 20 06-19-2011 09:55 AM
adjustable kickstand, lowering strap kit, lowering links Satan Parts, Gear and Accessories 5 10-01-2010 10:35 AM
NWS- Stretching is Important! JUPJON Adult Content - Photos / Videos - N.W.S. 11 08-13-2008 09:55 PM
Noob with guidance from INDY AlexxScott Welcome Newbies! 22 07-25-2007 08:23 PM
Stretching it? GARSZX10R Parts, Gear and Accessories 13 05-16-2007 06:17 PM
