Gen 1: 2004-2005 Mph help - Kawasaki ZX-10R.net
post #1 of 23 Old 02-03-2015, 01:50 PM Thread Starter
Magma05's Avatar
Mph help
What should my bike trap only mods are removed secondaries, yosh slip on, BMC race filter & 15/45 No TUNE i weigh 175 suited the bike sits at 66in.
60' 1.505
330 4.018
660 6.169
MPH 113.08
1000 8.062
1320 9.672
MPH 140.01
I feel like something is killing MPH i have heard of bikes with similiar weight riders and mods trapping well faster than that. Everyone keeps telling me with that 60' i should go faster. same thing when i was SWB went 1.62 60' but only went 6.62 @ 110. Any ideas what could be killing MPH? I thought the clutch at first but i didnt think it would 60ft what it does i have been in the 1.4x a few times on aborted passes.
Edit::::: Forgot i have a Shinko USoft
ID:	307177   Click image for larger version
2005 Magma ZX10R
1.41 60ft 1/4 9.28 @ 141
2001 ZX6R
1.81 60ft 7.51 1/8th @ 94
2005 Cadillac CTS-V
1998 Camaro SS H/C/I Nitrous
USMC Semper Fi
Magma05 is offline
post #2 of 23 Old 02-03-2015, 01:58 PM
LDH
LDH's Avatar
Probably the ridiculously long swingarm
Seriously I have no idea, but when I lived in Memphis I saw more guys spinning up than hooking up due to their swingarm length.
LDH is offline
post #3 of 23 Old 02-03-2015, 02:20 PM
TechX's Avatar
It could be wheel spin that's costing you some mph hard to feel on top. I found that as my 60 ft got quicker mph was down a bit and et was quicker. I would 60 foot in the low 1.3 range mph would be around 155 with and 8.95 et. When I got into the 1.2 60 foot range the mph would be 153 with and 8.83 or so et. This was on a super comp dragbike on NOS on the 8.90 index.
TechX is offline
post #4 of 23 Old 02-03-2015, 02:28 PM Thread Starter
Magma05's Avatar
I have heard that before as well because you leave harder that almost shortens the amount of time to build mph.. it doesnt make sense but it does kinda..
2005 Magma ZX10R
2001 ZX6R
2005 Cadillac CTS-V
USMC Semper Fi
Magma05 is offline
post #5 of 23 Old 02-03-2015, 03:27 PM
TechX's Avatar
Yes it is a bit weird but that's how it works. I didn't mind lower speeds if the et was better. The hot setup is a data logger and multi stage lockup clutch but you really have to be into dragracing to justify the cost.
TechX is offline
post #6 of 23 Old 02-03-2015, 10:48 PM
zx racer's Avatar
I think the gearing wats killin your mph. Try 16t on front next outin mph should go up.
05 ZX-10R SWB.
zx racer is offline
post #7 of 23 Old 02-04-2015, 01:03 AM
bluedevil's Avatar
many have great advice or insight...so my only thing I will add is what are other ZX10Rs doing with similar mods at your track?.....you can't go by MPH what you read through out the country only your Track as timing lights and MPH vary......I have been -1 +1 SWB 148mph and not near your 9.6s only 9.9s but bikes I was racing were hitting 145mph too...the ET is the only thing that counts, now if your loosing ET and MPH then there maybe a problem with setup.
Bloo
____________________________________________
Sent from My Computer via DSL mid to low service Firefox updated version, sometimes wireless sometimes Wire from the garage depending on connection speed.
bluedevil is offline
post #8 of 23 Old 02-04-2015, 06:02 AM
Blue08's Avatar
Location: Mentor on the Lake, Ohio/Broke at a dragstrip
MPH seems low for both your 1/8 and 1/4. but your times with your 60' seem right on point. A tune would definately help, having the secondaries removed, bmc filter and pipe though!
65, pos
8.67 @ 154mph
Blue08 is offline
post #9 of 23 Old 02-04-2015, 01:51 PM Thread Starter
Magma05's Avatar
Thanks guys i appreciate the help. I'll get this thing tuned and see what happens...
2005 Magma ZX10R
2001 ZX6R
2005 Cadillac CTS-V
USMC Semper Fi
Magma05 is offline
post #10 of 23 Old 02-04-2015, 03:26 PM
C3L1CA's Avatar
Trap does seem a little of low for the et.
Are you foot shifting or do you have an air shifter? 60' time seems pretty good but would've thought your 330 would be a tiny bit better too with that 60'
Could be your clutch slipping a bit too. I know I was able to cut similar 60' but my trap speed was down about 5-6mph compared to when I put a fresh clutch in it. Might be worth checking the stack height since its winter and know for sure
C3L1CA is offline
Mph Candy08 Test Area 2 02-17-2011 10:34 PM
Mph Candy08 Test Area 0 02-01-2011 04:10 PM
Mph 8/21-22/10 SUPER K Pictures and Videos 4 08-27-2010 09:50 AM
Droped the 10 at 0 mph ! K.A.T. The ZX-10R 41 06-24-2010 03:33 AM
183 mph.... Nick.INF The ZX-10R 41 04-30-2006 06:54 PM
