mounting shiftier - Kawasaki ZX-10R.net
post #1 of 5 Old 05-20-2013, 10:52 PM Thread Starter
Darmentle's Avatar
mounting shiftier
So i got the damn shiftier from mps and i don't have time to return it. The cloves that comes off the ram is machined to small it will not fit all the way over my shiftier. So i was thinking of drilling a hole threw my shiftier and then putting the pin threw. Thoughts?
07 zx10
DDM Hid Kit 8k
K&N Air Filter
Velocity Turbo kit
Evil Swing Arm
Gen 3 Motor
PC3
Darmentle is offline
post #2 of 5 Old 05-21-2013, 11:13 AM
gazx10's Avatar
shift kits are universal, takes a little fitting. that will work. make sure clevis floats on shift leverfreely. ive had to spread them slightly and uhave free travel on both ends of ram when mounted so it's not bottoming out. ram and clevis all floating freely, ur good to go.
gazx10 is offline
post #3 of 5 Old 05-21-2013, 01:21 PM Thread Starter
Darmentle's Avatar
Thanks again!
07 zx10
DDM Hid Kit 8k
K&N Air Filter
Velocity Turbo kit
Evil Swing Arm
Gen 3 Motor
PC3
post #4 of 5 Old 05-21-2013, 10:58 PM
mixedboitoo's Avatar
I had the same issue...what I did noticed was on the shifter, the mold has a hard line that makes the clevis hard to go over....I took my grinder and grounded both sides down jus enough to make sure the clevis has free motion and then I drilled the hole where I grounded down.....presto!!!!works
Like a charm
mixedboitoo is offline
post #5 of 5 Old 05-23-2013, 08:11 AM Thread Starter
Darmentle's Avatar
yeah i didn't want to drill a hole in my frame. so i used my heel guard as a bracket. and just drilled a hole threw the shiftier. Just make sure you space it out enough with washers so it doesn't bind.
07 zx10
DDM Hid Kit 8k
K&N Air Filter
Velocity Turbo kit
Evil Swing Arm
Gen 3 Motor
PC3
Cycle-Tek Shiftier Darmentle Strip 7 05-16-2013 03:33 PM
Camera mounting -- where?? dmj120 The Out House 1 07-02-2009 03:47 PM
GPS mounting? gooddesert Performance and Tech 4 01-28-2008 12:47 PM
Speedohealer mounting ? rojapar Performance and Tech 16 08-24-2007 01:57 PM
mounting bracket mr_get_iton Wanted: Buy or Trade 0 11-25-2006 10:33 AM
