Mirror removal/is it worth it? - Kawasaki ZX-10R.net
 2Likes
post #1 of 20 Old 10-25-2015, 10:59 AM Thread Starter
MPac's Avatar
I have guys at the track keep telling me I need to remove my mirrors and put blocks offs on, that it takes 12 hp to "push" them down the track and I'll pick up a tenth or so.
Is there any truth to this? Does anyone have any solid data that I'll pick up from removing them?
MPac is offline
post #2 of 20 Old 10-25-2015, 12:51 PM
zx racer's Avatar
12hp lol if anything you drop one, two pound weight saving thats it.
05 ZX-10R SWB.
zx racer is offline
post #3 of 20 Old 10-25-2015, 04:19 PM
TechX's Avatar
I never removed my mirrors when dragracing. I would pull them in closer to the fairing. If your looking for elapsed time nirvana then perhaps its worth removing them.
TechX is offline
post #4 of 20 Old 10-25-2015, 05:05 PM
D-CON's Avatar
I'm not aiming this at you but if removing mirrors picked up 12hp then it's the best kept secret in all of motorcycling! Removing them will reduce drag which will result in dropping time but your skill as a rider (and other factors in your favor - line, suspension, tuning) can more than overcome mirror drag i.e. mirrors won't be a deciding factor.
On the other hand, they're not necessary on the track and often times are required to be taped over if not removed anyway, per track rules, so it can only help, no matter how little.
D-CON is offline
post #5 of 20 Old 10-25-2015, 07:21 PM
Blue08's Avatar
Location: Mentor on the Lake, Ohio/Broke at a dragstrip
If there off how are you suppose to see how far the gixxer is behind you?
On a serious note the fact that someone at a drag strip said it takes 12 hp to "push them down the track makes me laugh. If that were the case I think we would see some top $$$ grudge racers cut a leg off bc they must take around 40hp to "push" down the track.
In all reality yes they will have more drag obviously but you will never see a difference on a time slip for a normal bike. If you just head to the track every now and then just fold them in like someone said above me
65, pos
8.67 @ 154mph
Blue08 is offline
post #6 of 20 Old 10-25-2015, 07:47 PM Thread Starter
MPac's Avatar
Lol I figured I'd throw the 12 hp comment in he made for your guys laughs, I run the strip alot, test and tune every Thursday, bracket Saturday (they are nice for bracket for judging the stripe against a faster bike) and I'm going to be hitting NHDRO next season. I've been street riding alot less due to how quick our bikes go through clutches but that's not a big issue to put them back on. I didn't know if I'd see a big difference on et, I figured at the most a couple hundredths with what I trap 9.30's at 146-147. But I will be on spray next season and I'm about to go from a 41 tooth rear to a 43 as soon as it arrives. Luckly my local track doesn't make us tape them up.
MPac is offline
post #7 of 20 Old 10-25-2015, 07:50 PM Thread Starter
MPac's Avatar
On a side note about a Gixxer, thrusday I ran against a pretty fast one on spray (8.60's bike) but even with my limited riding experience in general on a bike I still 60 footed 1.56 to his 1.60 and he weighs about 20-30 lbs less suited hehehe.
MPac is offline
post #8 of 20 Old 10-25-2015, 08:05 PM
Blue08's Avatar
Damn, an 8.60 with a 1.6 60' that bike would be nasty with a better rider
65, pos
8.67 @ 154mph
Blue08 is offline
post #9 of 20 Old 10-26-2015, 12:19 AM Thread Starter
MPac's Avatar
I asked him how big of a pill he had in it. He told me a 40 pill. I don't know if he just does an easier launch or what. He's stretched pretty good probably 12 inches, maybe he spun a little. I just felt got actually 60 footing someone for once. Haha. It's crazy how long our first gears are. On a side note I have a 43 tooth sprocket coming in and I'll have it on for Thursday, what should I expect with launching going up to that from my 41 tooth? If I was in my drag car I'd know what to expect changing the ring and pinion, I'm just not sure how it's going to effect the launch and how much I need to quicken getting my feet up to make that first shift. Typically my feet are up by around 80 or so feet out.
Your more experienced with this then I am so I respect your advice on this and forgive my newbness.
MPac is offline
post #10 of 20 Old 10-26-2015, 05:54 AM
Blue08's Avatar
Going up 2 won't be that much of a difference for the launch. It will make your first gear a little shorter which is good bc like you said they do have y'all first gears. I would launch a little lower than you do the first time just so you can see how it reacts with the new gear. I'm -1+4 on my gen 3 foot shifting and it's still not too terrible to get the foot up for the 1-2 shift.
65, pos
8.67 @ 154mph
Blue08 is offline
Gen 4: Mirror removal? silvrevo The ZX-10R 19 11-23-2015 07:10 PM
Gen 4 front mirror turn signal lense removal help needed 88sparky88 The ZX-10R 7 01-10-2015 09:55 AM
Mirror removal for track. nickalltogether Track 28 11-18-2010 08:01 PM
3rd Gen Mirror removal ronnulph The ZX-10R 1 04-30-2010 07:53 PM
Mirror removal on zx10 mlambert1987 The ZX-10R 12 03-15-2010 08:21 PM
