Mini Nos Hookup wiring....tps, gear position and tach signal?? - Kawasaki ZX-10R.net
post #1 of 2 Old 08-14-2011, 02:30 PM Thread Starter
ke2012's Avatar
Mini Nos Hookup wiring....tps and tach signal??
Need some help...tps i think is the yellow wire on main throttle position sensor and i can either get a tach signal off the gauge or a negative coil wire. Ive read that some folks cant get a tach signal off wire goin into the gauge cluster, so is better to get one off one of the coils? If so which one and which color wire?? They all have a red wire and a black stripped wire...which is the negative. Lastly...no clue where to tap into the gear position sensor for the pcv ....any help is greatly appreciated.
ke2012 is offline
post #2 of 2 Old 08-14-2011, 10:00 PM
Gen2 Ripper
neverendingmods's Avatar
I have called Holleys tech support and they can pull up your wiring diagram for COIL wire and tps. I use a pc3 with my nos mini dual stage + multihub. Also more people on psychobike.com run nitrous on 10's with that controller than on here so post over there too.
You will love that progressive controller man. I take out more and more ramp up every couple of months. When I get a real long arm, ramp up is going away.
07-ZX10R-SOLD
, 1/5th insert, -1/+5,comp werkes decatted,PC3+multi-hub,piperX,30 dry shot,2custom maps,Ballistic EVO2,Pazzo shorties,SATO rearsets,HealTech,ZG Corsa,EBC XC Gen3 rotors,Vesrah pads, SS lines, Gen3 calipers, etc and stretched 8" so it won't flip
05-ZRX1200R-sold
04-KX500-sold
1975 RD350-garage queen
neverendingmods is offline
Gen 3: ecu tach signal wire? bama~guy Performance and Tech 5 03-06-2011 12:03 PM
tach signal general01 Performance and Tech 2 05-16-2010 06:31 PM
Tach signal wire at guage panel dragracer Performance and Tech 6 08-14-2009 11:13 PM
WTB: '06-'07 Turn Signal Wiring rexwinter Wanted: Buy or Trade 3 01-29-2009 11:47 PM
WTB: 06' - '07 Turn Signal Wiring rexwinter Parts, Gear and Accessories 3 01-26-2009 10:05 PM
