Made some passes last night - Kawasaki ZX-10R.net
 3Likes
post #1 of 18 Old 06-18-2015, 04:02 PM Thread Starter
Millhouse's Avatar
Took my 07 back to the strip last night. Heres my setup
Stock height
Stock length
16/40 gearing
full muzzy exhaust
power commander with the dynojet tune for muzzy
195lbs suited
Best pass was this [email protected]
Still having trouble with the launch. Doesn't matter what I do, I can not do better than a 1.95. I can come out smooth, spin, bog, or wheelie and no matter what Im between 1.95 and 2.0. Thinking maybe I need to go up a tooth or two in the back? I also want to get the stuff to strap it, and lower the rear with the adjustable links I have. Let me know what you guys think.
Millhouse is offline
post #2 of 18 Old 06-18-2015, 04:18 PM
TechX's Avatar
Dang good for stock wheel base and your weight. Straping the front and lowering the rear will really help your launch. Typically you know the gearing is about right if you go thru the traps in 5th gear at redline.
TechX is offline
post #3 of 18 Old 06-18-2015, 04:33 PM Thread Starter
Millhouse's Avatar
Thanks man. I must need more gear then, because right now Im coming through at around 12k in 4th gear.
post #4 of 18 Old 06-18-2015, 06:59 PM
TechX's Avatar
Sounds like you might need a bit more gearing. I would strap and lower it first and see how she goes. Like most racing its best to make one change at a time.
TechX is offline
post #5 of 18 Old 06-19-2015, 09:04 AM
zx racer's Avatar
Good pass man exspecially at stock length, height. I suggest goin up 2 teeth on rear so you be top 5th at stripe. Strapin the front and lowerin the rear will help ton to!
05 ZX-10R SWB.
zx racer is offline
post #6 of 18 Old 06-19-2015, 09:49 PM Thread Starter
Millhouse's Avatar
Thanks guys, I think my next move will be to try lowering it. I have no intentions of making this a drag bike, but I have always wanted a 9 second pass so thats my current goal. Im hoping to do it SWB but if I end up having to buy some extension so be it
post #7 of 18 Old 06-23-2015, 09:05 PM
Blue08's Avatar
Location: Mentor on the Lake, Ohio/Broke at a dragstrip
Good luck it's addicting. You should see a big difference by just lowering it and strapping the front. Might even be able to add some teeth to your rear sprocket and still control it pretty well. Keep us posted
65, pos
8.67 @ 154mph
Blue08 is offline
post #8 of 18 Old 06-23-2015, 10:48 PM
bluedevil's Avatar
Agree!!!
You don't need more Gearing now you need more seat time I used mild gearing for years and with stock bike me weighing over 200lbs hit 9s many times with the same gearing your running.
straping and lowering along with seat time will give you the best and fastest results then play with gearing later on.
Don't stretch it until you get the 9s Stock Wheel Base that should be the Goal and will make you a better racer in the long run.
Again I always ran Stock through the Traps in 4th maxed out with 16/40 not bad and 9s runs as high as 148mph weighing over 200lbs geared Stock Wheel Base.....if he was stretched than yeah 5th or 6th Gear f'sho IMO.
Bloo
____________________________________________
Sent from My Computer via DSL mid to low service Firefox updated version, sometimes wireless sometimes Wire from the garage depending on connection speed.
bluedevil is offline
post #9 of 18 Old 06-24-2015, 09:45 PM Thread Starter
Millhouse's Avatar
Thanks for the input guys! I'll keep the thread updated for sure. Probably be a couple weeks before I make it back to the track. I'll leave the gearing alone for now and just lower it/strap it and see what I can do. I definitely would love to see a 9.XX SWB. I think I can do it, just need a little more practice launching.
post #10 of 18 Old 06-24-2015, 10:08 PM
TechX's Avatar
Bloo
That sounds reasonable for a stock wheel base bike with no bar's. My J motor drag bike I geared to hit redline in 5th thru the traps typical mph was 153 to 155 with an 8 second et.
TechX is offline
Gen 1: went and made some more motor passes tonight. new best inside cookmaster30 Strip 28 03-27-2012 07:17 AM
made a few more passes tonight and getting a little more satisfied with the bike cookmaster30 Strip 7 08-27-2011 08:08 PM
Got to make some passes on a Gsxr 1k last night bgmagma10 Strip 3 05-23-2011 12:55 PM
Made My First Passes, Looking for Advice bcm0018 Strip 15 09-21-2010 10:36 PM
Made a few passes on my ZX-10R GeorgeC Race and Stunt 4 04-28-2005 09:52 PM
