Made My First Passes, Looking for Advice - Kawasaki ZX-10R.net
post #1 of 16 Old 09-20-2010, 09:42 PM Thread Starter
Postwhore with an 04
bcm0018's Avatar
I went to the drag strip for the first time and made some passes. My best of the night was 10.53 @ 143.66. Here are some vids https://www.zx-10r.net/forum/showthread.php?t=94326 and I'll list out my some of the slips. SWB and height. Looking for any and all tips to go faster short of stretching it cause I'm never going to do it.
Thanks in advance!
60' 2.144
330' 5.082
1/8 7.285 @ 113.13
1000' 9.144
1/4 10.718 @ 143.17
60' 2.111
330' 5.091
1/8 7.261 @ 114.23
1000' 9.131
1/4 10.706 @ 143.38
60' 2.075
330' 4.950
1/8 7.118 @ 114.25
1000' 8.964
1/4 10.530 @ 143.66
60' 1.987
330' 4.918
1/8 7.181 @ 107.13
1000' 9.180
1/4 10.823 @ 138.22
60' 2.004
330' 4.899
1/8 7.132 @ 110.77
1000' 9.026
1/4 10.620 @ 141.77
60' 2.062
330' 4.924
1/8 7.116 @ 112.66
1000' 8.980
1/4 10.563 @ 142.64
Originally Posted by k_p_m View Post
PS. This is by far the most epic fail I have ever laid my eyes on. Holes in the ECU guy and "yut ugh" guy and NOS energy drink guy are all so relieved you came along and destroyed their epic failness with your damn speed holes in the frame.
IBSR
bcm0018 is offline
post #2 of 16 Old 09-20-2010, 09:51 PM
Teeks's Avatar
Leave at a higher rpm, and strap it. Those are the best two things i can think of without really modifying the bike. The first one just takes practice, leave higher in the rpms and use the clutch to do the dirty work. You need to be getting to wot quicker. Those are just my observations, but im no track expert either like some of the guys here are.
Originally Posted by -Op- View Post
Unless Scout says dont do it. Then, really, just do it.
Originally Posted by or10r View Post
I know its blistering fast but you cant outrun ugly.
Teeks is offline
post #3 of 16 Old 09-21-2010, 04:32 AM
zx racer's Avatar
nice passes & def strap the front end and work on that clutch hand, your 60 is suffering. seat time is the key to goin fast. do you remember wat rpms you was launchin at ?
05 ZX-10R SWB.
zx racer is offline
post #4 of 16 Old 09-21-2010, 07:25 AM Thread Starter
bcm0018's Avatar
Thanks!! I was leaving around 7-8K rpm should it be higher? I'll look into strapping in it and I could probably lower it easily cause I have an ohlins rear shock so I'm pretty sure I can adjust the rear height and dropping the front is easy.
Okay thanks!! I was leaving around 7-8K rpm should it be higher? What should a good 60' be?
IBSR
bcm0018 is offline
post #5 of 16 Old 09-21-2010, 09:17 AM
codyc_13's Avatar
SWB I was doing 1.71s that was lowered and strapped
codyc_13 is offline
post #6 of 16 Old 09-21-2010, 10:33 AM
Shorty's Performance
madnessracing's Avatar
Strap the front end and practice a lot!
madnessracing is offline
post #7 of 16 Old 09-21-2010, 11:08 AM
Slow Poke
bgmagma10's Avatar
yes def a strap. and 60ft practice. i've herd that droppin a 10th in the 60ft is good for 3 10ths in the quarter. so thats the most important part
bgmagma10 is offline
post #8 of 16 Old 09-21-2010, 12:18 PM
evolanceroz's Avatar
Images: 11
Send a message via AIM to evolanceroz Send a message via Yahoo to evolanceroz
i leave around the same rpm. clutch control that is the key. You can full throttle after all you want but if you cannot slip the clutch while doing it you might as well take off like you do from the stop light. To me it didnt look bad. Any higher rpm depending on your weight you will pull the front end too high. my avatar pic was at 7500 rpm
evolanceroz is offline
post #9 of 16 Old 09-21-2010, 12:19 PM
Images: 11
listen to that madness cat. You should look at his videos he leaves the line like a mac truck just plowed into him.
post #10 of 16 Old 09-21-2010, 02:18 PM
zx racer's Avatar
thats a good rpm to start with. 1.7's is a good 60 imo swb but with practice you could probly do better. also how much do you weight ? i launch between 8-9k on my swb 05 and slip the clutch to control wheelies while keepin the throttle pin and i cut low to mid 1.6's 60ft's and im probly a lil heavier than you
05 ZX-10R SWB.
zx racer is offline
here is one of my passes xspower Strip 19 10-08-2008 04:34 PM
First 1/4 passes - 08 ZX-10 Patrick Strip 5 10-06-2008 06:41 AM
How many Passes FAF Pictures and Videos 19 10-15-2007 12:08 PM
Laguna Moto GP Paddock Passes and 3 day passes RickRoush03 Parts, Gear and Accessories 12 07-14-2006 05:27 PM
Made a few passes on my ZX-10R GeorgeC Race and Stunt 4 04-28-2005 09:52 PM
