Lowering link stuck - Kawasaki ZX-10R.net
post #1 of 2 Old 02-27-2013, 10:25 PM Thread Starter
Darmentle's Avatar
Lowering link stuck
I'm trying to get the bike Ready for next weekend. And I go to lower the bike down and the bolt is stuck and the shim is half way out binding up on each other. Shit will not move I've tried going up and down still nothing even used lube and some force. I loosens the top bolt to nothing. Thoughts bike is teetering on the stand
07 zx10
DDM Hid Kit 8k
K&N Air Filter
Velocity Turbo kit
Evil Swing Arm
Gen 3 Motor
PC3
Darmentle is offline
post #2 of 2 Old 02-28-2013, 10:29 AM
Slow Poke
bgmagma10's Avatar
Its easier if you put leave it on the kickstand and put a small jack right under the knuckle of your shock just to barely take pressure off the shock. If the 2nd gens are like the 1st gens you need to take a flat head screw driver and push the spacer out enough to get a hold of it and pull it out then you can pull the bolt out. I don't like doing it on the rear stand because like you said it will teeter pretty bad.
bgmagma10 is offline
lowering link? hitithard General Motorcycle Discussions 1 04-08-2012 10:18 PM
Wanted: gen 1 stock rear link to replace lowering link. aszrael1266 Wanted: Buy or Trade 1 03-14-2012 01:05 PM
Gen 4: Lowering link.....$35 shipped. NinjeR Parts, Gear and Accessories 10 12-21-2011 01:29 AM
lowering link question SoJersey10R Performance and Tech 3 08-19-2009 09:15 AM
Lowering link dirt ninja Performance and Tech 3 07-18-2007 06:16 PM
