Low Trap speed through the 1/4??? - Kawasaki ZX-10R.net
post #1 of 22 Old 09-10-2012, 03:08 PM Thread Starter
Savage05's Avatar
Images: 7
So I thought my clutches were slipping and causing my trap speed to be low. I replaced my clutch with the Drag Pak from Cycle Concepts and felt an undeniable gain! I took it to the track this weekend and no change.
OEM clutch- [email protected] 135 1.73 60ft. (78 degrees)
Drag Pak- [email protected] 134 1.81 60ft. (90 degrees)
Bike is stock wheelbase, lowered 3" and strapped. BMC filter, Mivv GP slip-on, v-stacks, -1 +2 520 conversion. I'm 210lbs suited.
I obviously need a lot more seat time but I would think the mph would better than that. What do you guys think?
Savage05 is offline
post #2 of 22 Old 09-10-2012, 03:25 PM
Slow10r's Avatar
how many miles on the bike, has it ever had a valve adjustment? it seems like your 60fts are there for a 9 sec pass but u have no top end, mine with a 1.9 60ft did a 10.1 at 140, worst pass of the night i trapped 138 and i am stock motor completly. Is your bike tuned?
Slow10r is offline
post #3 of 22 Old 09-10-2012, 03:35 PM Thread Starter
Savage05's Avatar
Images: 7
It's never had a valve adjustment. It has a little less than 13k miles. Bike was dyno tuned a few weeks ago.
Savage05 is offline
post #4 of 22 Old 09-10-2012, 04:59 PM
Post Whore
-Op-'s Avatar
12* temperature change affects it for sure. I know my 10 hates the heat. Reminds me everytime I ride it in it.
-Op- is offline
post #5 of 22 Old 09-10-2012, 05:55 PM
Slow Poke
bgmagma10's Avatar
Your weight and temp says a lot. What about humidity? Tire pressure makes a big difference too. That's nothin to be ashamed of though man.
bgmagma10 is offline
post #6 of 22 Old 09-10-2012, 11:02 PM Thread Starter
Savage05's Avatar
Images: 7
I don't lower my tire pressure since its stock wheelbase. I keep it around 36psi. My times really piss me off though! I won't be happy until I hit a 9.70 with it short armed.
Savage05 is offline
post #7 of 22 Old 09-10-2012, 11:54 PM
Supercharged Mod
Mine is in the same range. Engine is stock and has not been touched. Stock exhaust, too (your slip-on is probably not really helping much).
Mine is coming up on the 72,000 km major service, and I strongly suspect that this time, it's going to need some work.
GoFaster is offline
post #8 of 22 Old 09-10-2012, 11:55 PM
Slow10r's Avatar
do you use your clutch when you shift?
Slow10r is offline
post #9 of 22 Old 09-11-2012, 12:02 AM
Supercharged Mod
I have a quickshifter installed. It didn't make an appreciable difference to the trap speed.
GoFaster is offline
post #10 of 22 Old 09-11-2012, 12:10 AM
bluedevil's Avatar
Really what you need is a comparison.....I am lucky enough to have member 1killer that lives in my town his bike is modified almost like mine but he has a quickshifter.....but my bike has over 30,000 miles his about half of that mine has a valve adjustment, and not only that I use to do up to 148mph at the 1/4 even on a 10s run..lately we have run together he gets 9s or close like a 10.0 and we both have the exact same MPH most times.
I was told the track did some adjustments and ever since then my MPH has been low. only know it's on par with a similar bike like 140mph witch helps ease my concerns....hope that helps
bloo
bluedevil is offline
Gearing and 1/4 mile trap Jripp860 Race and Stunt 10 10-16-2011 10:37 PM
Trap Speeds rafa Strip 8 04-14-2011 12:10 AM
What can I expect? Passed a speed trap.... 06wreckedzx10 General Motorcycle Discussions 24 05-13-2009 12:43 PM
[B]speed trap[/B] vinja314 The Out House 4 06-15-2007 12:48 AM
Speed Trap website RickRoush03 The Out House 7 01-17-2006 06:23 PM
