low mph must be ohio??? - Kawasaki ZX-10R.net
post #1 of 9 Old 07-04-2010, 02:07 PM Thread Starter
i got the chance to run on the 2nd my bikes only mods r still lowered 3",strap,yosh slipon and i just removed the secondary butterflies to days prior of the 2nd
i ran at 10:58pm 65 degrees out + or - and good track prep
reaction-.455(redlight)
60ft-1.67
330ft-4.43
[email protected]
1/8 et-6.58
1/8 mph-114
1/4 et-10.09
1/4 mph-135
the thing i tried dif. was raised my rpm's when i launched(that helped the studdering feeling)and i made sure i was getting full throttle i dont know if takin those secondaries out helped me out but it seemed like it but that could of been the temp and track prep as well it feels like it gots a little more in it so untill i hit 9.99 or better i think im gonna keep the stock sprockets on eventually i will change them out
jake_04_10r is offline
post #2 of 9 Old 07-04-2010, 05:17 PM
JLAudio11's Avatar
Alot of times late at night like that times go up because of dew setting in and humidity going up which will hurt your times. When pullin the flies its definitely a good idea to get remapped because it will run lean in that area that the ecu would normally have them closed or partially open. Thats still an improvement though isnt it on et and mph?
'06 "Corn Burner" Edition ZX10R
w/ a lot of bolt-ons
PERFORMANCE CYCLE 2 Racing
JLAudio11 is offline
post #3 of 9 Old 07-04-2010, 05:27 PM
bluedevil's Avatar
I am thinking it has something to do with your track and timing sensors. I say that because you got a very good 1/8 mile time which tells me you where WOT but still picked up only 21mph on the back half. If you weren't close to the 9s I would say you messed up somewhere on the back half but your 10.00s tells me you didn't do nothing wrong it's on par or what to expect.
I really don't know it's just a guess and the fact you said a buddy or something is running the same MPH or close.
Anyway....
bloo
bluedevil is offline
post #4 of 9 Old 07-04-2010, 05:54 PM
Quick10's Avatar
The stuttering is most likely because of the secondaries...Esp @4k RPM so I hope you are well above that at launch
Originally Posted by NinjeR View Post
I'm glad I'm a stripper, the money keeps coming in! lol
Quick10 is offline
post #5 of 9 Old 07-04-2010, 10:02 PM
bluedevil's Avatar
He did a 1.67s in the 60 and 6.5s in the 1/8th......that is a setup for 9s but his ET MPH is not adding up(with Mods) from the 1st half but there is NO "Stuttering" going on....just the mystery MPH readings.
post #6 of 9 Old 07-04-2010, 10:46 PM
codyc_13's Avatar
I'm with blue on this one. I think its just the mph sensor... I went and dug up a old stock wheelbase timeslip that was close to yours on times and this is what I got
60' 1.69
330 4.36
1/8 6.48
Mph. 115.12
1/4. 9.95
Mph. 143.01
So what this tells me is that I finished the back half in 3.47 seconds and you finished in 3.51 seconds..virtually identical...BUT I gained 8 more MPH, that doesn't match up which leads me to believe Blue hit the nail on the head.. I hope I didn't confuse anyone with that
codyc_13 is offline
post #7 of 9 Old 07-05-2010, 10:52 AM
tone.r's Avatar
60ft-1.67
330ft-4.43
[email protected]
1/8 et-6.58
1/8 mph-114
1/4 et-10.09
1/4 mph-135
what track was you at?
Tone.R {checkmate}
Do what makes u happy whatever it is.....Roberson Racing
tone.r is offline
post #8 of 9 Old 07-05-2010, 03:56 PM Thread Starter
yes this is an improvement that is my highest mph yet
i raced at m.c.i.r(marion county international raceway)
post #9 of 9 Old 07-05-2010, 06:00 PM
bluedevil's Avatar
Even with my clutch problem I have now my last time out I still did a 10.0Xs which was almost Identical to your times:
60ft-1.67
330ft-4.43
[email protected]
1/8 et-6.58
1/8 mph-114
1/4 et-10.09
1/4 mph-135
I was 1.68s/116mph 8th @6.6s....bad time for the 8th I know I like to be in the 6.5s but finished at 148MPH 10.02s...the ZX10R I was racing(1st Gen) was doing 144mph with a 10.18s.....I don't believe are bikes are any faster on the back half it has to have something to do with the tracks themselves IMO... and as JLAudio11 said before elevation should not be a factor. just
bloo
low mph in the 1/4 10.27 133mph and???? jake_04_10r Strip 19 06-27-2010 11:22 PM
yosh exhausts for the low low lexusrx Vendors deals 4 11-24-2009 08:38 AM
Ohio -- 5/15 -5/17 -- Hocking Hills, SR 555, SE Ohio, etc -- Camping Satan Regional Forums 0 04-16-2009 10:56 PM
2003 zx-9R-low low miles master link Bikes 4 Sale 0 08-16-2008 01:51 AM
mph ok?or kinda low? inginekilla Strip 11 03-19-2008 11:08 AM
