Losing times and mph all over the place. - Kawasaki ZX-10R.net
post #1 of 18 Old 08-05-2010, 12:56 AM Thread Starter
stretched10R's Avatar
Ok I took my bike back to the track tonight and was not happy with any of my times,I replaced my plugs and changed my gearing after my last trip to the track because I wasnt happy then.That wasnt my problem,I cant get the bike to 60 ft for anything anymore and my times went from consistent 9.30's at 147-149 to 9.70's at 139-141,60'ft dropped from 1.50's to high 1.60's. Im now running the same numbers on spray that it was running on motor before.It still has factory clutches.I did check them and they all were in spec and weren't worn so bad they needed replaced.COuld it still be the clutches??
Born with that MAD KAW DISEASE!!!!!
stretched10R is offline
post #2 of 18 Old 08-05-2010, 11:14 AM
Slow Poke
bgmagma10's Avatar
it could me pushing through the clutches on the top end but prob not. what was the air temp before and after? and gearing it will drop your mph on the top end too.
bgmagma10 is offline
post #3 of 18 Old 08-05-2010, 11:17 AM
Slow Poke
bgmagma10's Avatar
have you put anything else on the bike?
post #4 of 18 Old 08-05-2010, 11:35 AM
Slow Poke
bgmagma10's Avatar
with cold cold air i've gone a 9.51 swb. but in the heat its 9.70's-9.80's
post #5 of 18 Old 08-05-2010, 12:44 PM Thread Starter
Iwas running 9.30's in may,ya it wasnt as hot then but it was still hot out.It is the clutches,just took the bike out on the street and launched hard,airshifted to 2nd and it free revd.There cooked.
post #6 of 18 Old 08-05-2010, 08:04 PM
Send a message via AIM to Cycle Concepts
you have a combination of things that are affecting your performance right now..you have found one with the clutches...but your second issue is gonna be the weather...the humidity has been robbing everybody this year..get your clutches replaced and you will get back alittle but not all..atleast not until the humidity subsides alittle..
Cycle Concepts is offline
post #7 of 18 Old 08-05-2010, 11:58 PM
Slow Poke
bgmagma10's Avatar
lol there ya go. have you used the cycle concepts clutch? it's freakin awesome! i won't ever use another
post #8 of 18 Old 08-06-2010, 12:07 AM
bluedevil's Avatar
for the price I don't blame you....it's OEM part # plates just a different configuration/part #s in the stack....and nothing is better than OEM plates for the 10Rs for us stock guys ...on my second PAK of Cycle Concepts.
bluedevil is offline
post #9 of 18 Old 08-06-2010, 01:11 AM
JLAudio11's Avatar
Thanks Blue, I was wonderin if they were his own manufactured plates or some kind of combo of others. I've heard nothing but great things about them. I will definitely be goin to Dwayne when these ORIGINALS finally wear out. Besides my basket tryin to grenade, I've been very happy with the 10 clutch. SWB all last year cuttin 1.58's and have only replaced the steels this year, with kg clutch factory steels my buddy had at his shop. Still runnin the same fibers that were in it when I got it over a year ago!
'06 "Corn Burner" Edition ZX10R
w/ a lot of bolt-ons
PERFORMANCE CYCLE 2 Racing
JLAudio11 is offline
post #10 of 18 Old 08-06-2010, 07:29 AM Thread Starter
Ya,I tore it apart and my steeles are all blue,they got hot as hell,gona replace everything and not just certain things,I just had it apart about a month ago to welding up the basket,should have replaced it all then
Losing my nuts killersrt The Out House 23 04-06-2009 04:53 AM
losing his hearing red636girl The Funny Pages 1 10-21-2008 11:42 PM
Losing a Friend themightymezzo The Funny Pages 5 10-05-2007 08:32 PM
losing power nobody Performance and Tech 3 08-09-2006 12:53 PM
im losing it ....!!! BMW528I The Out House 12 03-12-2006 02:33 PM
