Look inside - Kawasaki ZX-10R.net
post #1 of 7 Old 07-05-2013, 12:56 PM Thread Starter
zx-sik-r's Avatar
Look inside
DME sells these brackets for the suzukis but not for the Kawi so I had these made,if your running a low pro front tire to lower your front end these brackets allow you to lower the front fender which allows you to lower the front end even more
zx-sik-r is offline
post #2 of 7 Old 07-05-2013, 01:17 PM
SIgixxer80's Avatar
Nice!
2004 zx10-66"wb, cut forks, flat link, pc3 w/hub, drag pak, bmc race filter, sidewinder, -1/+6 gearing
SIgixxer80 is offline
post #3 of 7 Old 07-05-2013, 02:01 PM
eklikewhoa's Avatar
Verycool
Sent from my HTC One
eklikewhoa is offline
post #4 of 7 Old 07-07-2013, 07:59 PM
BGoodwin22's Avatar
Very nice. I had thought about this a while back but didn't pursue it because my front tire is brand new so it'll be a bit before I switch to a lo pro. What are the dimensions?
BGoodwin22 is offline
post #5 of 7 Old 07-07-2013, 08:06 PM
mixedboitoo's Avatar
How much would u charge to get some more made? For a 3rd gen......I was going to do this same mod with some aluminum from lowes but I got lazy and those loook hella good....props
mixedboitoo is offline
post #6 of 7 Old 07-07-2013, 10:05 PM Thread Starter
zx-sik-r's Avatar
I can have them made for $140 shipped.yes this is highly expensive compared to DME but they aren't being made by the dozens in a CNC machine...takes time in a mill AND I have to drive 45 min each way to pick them up.
zx-sik-r is offline
post #7 of 7 Old 08-06-2013, 06:49 PM
very nice
beanedisel is offline
Outside-Inside-Outside Bond The ZX-10R 24 10-14-2011 08:24 PM
Inside '11 10R Ninjutsu The ZX-10R 25 08-05-2010 10:25 PM
Took the head out, take a look inside Boricua Performance and Tech 29 08-30-2006 07:19 PM
Inside Scoop trkstarr The ZX-10R 12 02-03-2004 06:50 PM
