Lets talk track prep maintence - Kawasaki ZX-10R.net
post #1 of 39 Old 08-11-2011, 12:25 PM Thread Starter
zx racer's Avatar
hey guys im interested in hearing wat some of you guys do to your bikes before you head to the track or in between rounds while your there. any speacial tips you guys do to keep the clutch cool down and how long do most of you'll wait to run between rounds. so lets hear it guys
05 ZX-10R SWB.
zx racer is offline
post #2 of 39 Old 08-11-2011, 04:01 PM
formerly GHOST RIDER
SOUN1's Avatar
I check for leaks and make sure everything is tight..Check all fluids, all the bike's normal functions, check the chain tention and lubed it,also check your gas tank.That's about ti for me.
Never forget who helped you!
Never forgive who fu*ked you.
Doing a trackday is like "SEX", no matter what happens you'll want to hit it again..
SOUN1 is offline
post #3 of 39 Old 08-11-2011, 04:15 PM
Newfie Bullet
craig_sez's Avatar
Images: 34
chk for leaks,chk tire pressures when u come off the track so you know hot tire temps and adj as you like..top off fuel as needed,chk fluid levels,chain slack..keep bike in shaded area with a fan on the engine and if i think of it i keep gas in a cooler storage area...Make any suspension adj when suspension is hot and finally put on my tire warmers..
Get down to my skivveys,chill suck back lots of water...
craig_sez is offline
post #4 of 39 Old 08-11-2011, 04:38 PM Thread Starter
zx racer's Avatar
im sorry i shouldve worded it more clearly in the original post but i was manily interested in track prep maintence for the dragstrip but you guys do have pretty good ideas.
05 ZX-10R SWB.
zx racer is offline
post #5 of 39 Old 08-11-2011, 04:44 PM
mrbzx7's Avatar
I pull my clutches and soak them in oil at least once a week (2 trips to the track), also clean chain with diesel and re lube.
mrbzx7 is offline
post #6 of 39 Old 08-11-2011, 09:33 PM
codyc_13's Avatar
In between rounds I pull my oil cap and zip tie my clutch lever to let the heat out of the clutch. Check tire pressure before each round.
Sponsored by:
Vaughan Racing
Synthetic Shield
Moline Bar
codyc_13 is offline
post #7 of 39 Old 08-11-2011, 10:53 PM
cookmaster30's Avatar
i never thought of that. keep talking cody and people might think u know a thing or two.
cookmaster30 is offline
post #8 of 39 Old 08-11-2011, 11:06 PM
bluedevil's Avatar
I actually learned that trick over 6yrs ago from the late Great Ruthless Racing(RIP) but the Zip Tie is a good idea because if you do that you better make sure in your haste when they call you up to the line you didn't forget you pulled the oil cap......so another good tip with the zip tie or at least something to remind you.
bloo
bluedevil is offline
post #9 of 39 Old 08-12-2011, 01:46 AM
Slow10r's Avatar
these are some great tips, what tire pressure do you run? last time i went out, i had it at 30psi, and wouldnt stop spinning, so, i dropped it to 18 and it did ok, but dropped my mph. right now its just a street tire, damn angle tire, next will be a shinko drag radial with 7 inches of stretch
Slow10r is offline
post #10 of 39 Old 08-12-2011, 11:18 AM Thread Starter
zx racer's Avatar
yea i was told this saves on clutch life by alot of guys at the track and i stay up to par on chain maintence bc i had one fail on me on another bike at 130mph and it was a scary sight.
this is a great tip to do and i actually do this myself but leave my key down by oil filler cap so it remind me to screw the oil cap back on.
05 ZX-10R SWB.
zx racer is offline
Gen 4: Lets talk air filters likingbiking Performance and Tech 1 08-04-2011 03:04 AM
College hoops! Lets talk about it! ZiG 9th The Out House 72 04-08-2009 01:03 AM
lets talk cell phones solar10 The Out House 36 04-04-2009 12:16 PM
Son, lets talk about rubbers... BenRyDn The ZX-10R 20 01-30-2005 11:45 PM
