Lanyard mounting problem - Kawasaki ZX-10R.net
post #1 of 18 Old 05-21-2012, 05:44 AM Thread Starter
All show and all go 10r
JLG0987's Avatar
First off I think it's kind of retarded you need a lanyard for street legals considering there's a tip over switch but anyway. I have no room. I can probably get away without it next time as I haven't brought the 10R to the strip yet and I got a warning the last time.
I wanted this
http://www.schnitzracingstore.com/ca...howprevnext=1#
but it wont bolt on to anything I have, nothing on the bars other than the switches are stock. Any ideas guys? Pics to help me out.
JLG0987 is offline
post #2 of 18 Old 05-21-2012, 06:19 AM
SkyDork's Avatar
Get a lanyard with a screw terminal at the end. Then use a self tapping screw to attach it to your existing kill switch. You screw it to the bottom "run" position so if you come off the bike, the lanyard pulls the switch to the kill position. Cheap and easy and I've done it before with good luck. When not in use, just loop the lanyard over the clip-on.
#WordCrimes
SkyDork is offline
post #3 of 18 Old 05-21-2012, 06:33 AM Thread Starter
JLG0987's Avatar
Ya I've seen that but I really don't want to do that as it looks kind of half assed.
JLG0987 is offline
post #4 of 18 Old 05-21-2012, 06:44 AM
ZX-10R enthusiast
dudewhrsmybike's Avatar
This only works depending on how strict their tech guys are with motorcycles....in the past I've just bought a keychain coil cord and velcro'd it to my kill switch. It was good enough for them...
Strictly for my Ninjas
https://www.instagram.com/mistr.123/
Current Ride: 2016 ZX-10R ABS (under construction)
Former Ride: 2011 ZX-10R ABS
17/41, Woolich Racing Tuned ECU and QS, Rifleman's 1/5th throttle insert, CL XBK5 pads, Yosh case sliders, Mivv Carbon w/ Ti Akra link
dudewhrsmybike is offline
post #5 of 18 Old 05-21-2012, 04:33 PM
BratNetwork's Avatar
How about the Orient Express one. I have that one and its great and it replaces the clamshell half of the master cylinder clamp so you dont need any extra space.
2008 ZX-10R | Black | Arrow Headers | AreaP Slip-on CF | K&N Filter |GUTS ECU Flash By Guhl Motors | Block-Off Plates | Fender Eliminator | Clear Alternatives Integrated Taillight | Rifleman's 1/5th Throttle Insert | Speedohealer | Pro-Grip 719s | Vortex Bar Ends | Puig Z DB Windscreen | CBR1000 Mirrors | Vortex 520 Sprockets -1/+1 | RK Gold 520 Chain | Galfer SS Lines | Pazzo Shorty Levers | Vortex Gas Cap | Rebuilt Damper | Lightech Rearsets | Much More To Come
BratNetwork is offline
post #6 of 18 Old 05-21-2012, 04:42 PM
Actually now that I look closer so does the one you listed.
post #7 of 18 Old 05-21-2012, 04:57 PM
fernman's Avatar
^^^yes that one ^^^ PMR makes them, I have the one like JLG0987's but I ground mine to fit.
another alternative Isee on a lot of bikes is just put some bubble gum on a shoe string so it will look like sheet!
You only go around once, enjoy the ride...
fernman is offline
post #8 of 18 Old 05-21-2012, 05:41 PM
Post Whore
-Op-'s Avatar
http://www.orientexpress.com/p-14470...um78-bar-.aspx
this is the other option. those are supposed to mount to your Master Cylinder. Lookin at the pics you posted, I want to clarify, what prevents you from mounting to there? You unbolt the clamp that holds all the wiring and tether for the switch in place of the clamp you already have. I just cant tell why you wouldnt be able to, so insight would be great?
For mine, Ill get you a pic later, but I have the stock forks on my Gen 1 an have one of the "older" style that is supposed to loop around the bar and is all contained to itself. Instead, I just mounted it to the top of the fork around the preload adjuster and it stays put. Unfortunately, thats no help in your situation.
-Op- is offline
post #9 of 18 Old 05-21-2012, 06:01 PM Thread Starter
JLG0987's Avatar
The bar clamp on the brembo mc isn't straight up and down it's offset. like a 15 degree angle.
JLG0987 is offline
post #10 of 18 Old 05-21-2012, 06:07 PM
Post Whore
-Op-'s Avatar
I see it now. Can you rotate the throttle housing at all? or would that mess something up or hit something?
-Op- is offline
Gen 3: Looking for some nice Lanyard kill switches. jabs08zx6r General Motorcycle Discussions 7 05-01-2011 11:38 AM
Help - GPR mounting not right..? jdm123 General Motorcycle Discussions 13 02-27-2009 02:33 PM
GPS mounting Older Guy The ZX-10R 25 12-07-2008 11:03 AM
GPS Mounting? morrisjl2 The ZX-10R 19 01-08-2006 08:18 AM
Tag mounting? Ground Zero The ZX-10R 36 03-24-2005 04:08 AM
