just a quick ? about race gas? - Kawasaki ZX-10R.net
post #1 of 31 Old 08-28-2010, 05:30 PM Thread Starter
codyc_13's Avatar
What's up guys..I am trying to squeeze every little bit of hp out of the 10. I'm trying to outrun my buddies honda. I'm fixing to get a power commander. I have race baffles with a gutted cat. After I get the power commander I'm going to pull the secondary flies put a race air filter. I also have a tre...my ? is will race gas get me any more power. A full exhaust and tune isn't in my budget right now. So it will be race gas with a loaded map...also what type of fuel is best for my circumstances
Sponsored by:
Vaughan Racing
Synthetic Shield
Moline Bar
codyc_13 is offline
post #2 of 31 Old 08-28-2010, 05:41 PM
Quick10's Avatar
No race gas you can try running 89. Your just pissing your money away if your bike doesn't need it
Originally Posted by NinjeR View Post
I'm glad I'm a stripper, the money keeps coming in! lol
Quick10 is offline
post #3 of 31 Old 08-28-2010, 05:48 PM
zx racer's Avatar
ive had good look with useing MR9 & MRX01, both are oxygenated and make good power on all motor applications.
05 ZX-10R SWB.
zx racer is offline
post #4 of 31 Old 08-28-2010, 06:00 PM
bluedevil's Avatar
Many discussions in the past about race fuel and from all the reading on this site and reviews it doesn't help much unless the bike is tuned for a particular fuel.....best bet is run 87.
bloo
PS...you have 2 duplicate threads......will try to merge them into one now.
bluedevil is offline
post #5 of 31 Old 08-28-2010, 06:08 PM Thread Starter
codyc_13's Avatar
Thanks blue.. All I have for internet is my blackberry and the search function doesn't work right...it also duplicates a lot of posts, I try to delete them when I realize it but it wouldn't let me delete the whole thread.
codyc_13 is offline
post #6 of 31 Old 08-28-2010, 07:21 PM
Supercharged Mod
"Race gas" is not one single thing. There are many customized fuels available.
On an otherwise standard bike, you could try using a fuel that is intended for maximizing power on a production engine. Talk to your local race fuel distributor.
And having said that ... I run my race bike on plain ordinary Shell V-power.
GoFaster is offline
post #7 of 31 Old 08-28-2010, 08:13 PM
gazx10's Avatar
mr9
vp mr9, you WILL pickup power, developed for todays stock sportbikes. 87 octane, oxygenated, extremely fast burn for max cyl. pressure, will produce results. seen 5-7 hp on dyno with no mapping. but dyno confirms this also.
gazx10 is offline
post #8 of 31 Old 08-28-2010, 08:19 PM
bluedevil's Avatar
Originally Posted by gazx10 View Post
vp mr9, you WILL pickup power, even on a stocker. oxygenated, extremely fast burn for max cyl. pressure, will produce results. seen 5-7 hp on dyno with no mapping.
did you tell him about the side effects though like gunk....will have to do a search but don't believe it's like through this fuel in and have fun....there is work involved to make sure your bike goes back to normal after runs.
post #9 of 31 Old 08-28-2010, 08:24 PM
den33's Avatar
Is it okay to run 89? Thought it was bad for motor
den33 is offline
post #10 of 31 Old 08-28-2010, 08:36 PM
Supercharged Mod
A good many racing fuels have a very short shelf life after the container (with 20 litres in it) is opened, and a good many of them are not good to stay in contact with the various plastic or rubber parts in fuel systems in the long term ... and some of them have some rather scary words on the MSDS, too.
too much aggravation and cost in MY situation ...
GoFaster is offline
??Dyno jet Quick shifter W/ Race ECU?? Ninja187 Performance and Tech 0 06-30-2009 11:27 AM
04-07 ZX-10r Kawi Race cams, thin head gasket and race springs heads up!!! garth285 Parts, Gear and Accessories 4 07-24-2008 10:03 AM
Quick ? about race/stock plastics tical The ZX-10R 5 07-01-2008 01:11 AM
Quick Quick Shifter Q OneSLOW10 Performance and Tech 7 06-11-2008 02:15 PM
Race Report - Canadian(regional) RACE Superseries Round # 2: Shannonville Pro Track booneylander Track 3 05-22-2007 03:32 PM
