i finally got to run 1/4 mile - Kawasaki ZX-10R.net
post #1 of 10 Old 10-05-2010, 09:52 PM Thread Starter
zx-sik-r's Avatar
fixin to build a new setup so ill throw some times out.after fighting setup trying to figure out a gear all day i went a 8.46 at 155mph.this is a stock clutch/engine bike with just a head and 50 shot dry.i rolled off a good 25-30ft before the traps so im sure it would have went faster.im also a 190lb rider suited.
zx-sik-r is offline
post #2 of 10 Old 10-05-2010, 09:57 PM
strkd50's Avatar
Good to see a fellow 10 running those times, thats on a 70" if I remember right?
2012 ZX-14R
#228
strkd50 is offline
post #3 of 10 Old 10-05-2010, 10:02 PM
Certified SLOW
nolaZX10's Avatar
Thats... sik
So what gearing did you end up running that with?
Best 1/4mi ET: 8.98 @ 147 (stock motor, no turbo/nitrous)
nolaZX10 is offline
post #4 of 10 Old 10-05-2010, 10:04 PM
strkd50's Avatar
Originally Posted by nolazx10 View Post
thats... Sik
so what gearing did you end up running that with?
2012 ZX-14R
#228
strkd50 is offline
post #5 of 10 Old 10-06-2010, 07:57 AM Thread Starter
zx-sik-r's Avatar
thats... Sik
16-41 and i rolled off cause i was in a grudge race and wanted to close the gap,had plenty of gear left
zx-sik-r is offline
post #6 of 10 Old 10-06-2010, 09:31 AM
tone.r's Avatar
WOW damn good run what does the bike run on motor? if you run the bike on motor do you run the same gearing im playing around with gearing to and running out of time its getting cold around here. im going to try 16t 46t then 17t 46t this week im 215suited.
man whats your 60s 1.3s?
Tone.R {checkmate}
Do what makes u happy whatever it is.....Roberson Racing
tone.r is offline
post #7 of 10 Old 10-06-2010, 03:38 PM Thread Starter
zx-sik-r's Avatar
gearing depends on hp and weight,i couldnt tell you in the 1/4 but in the 1/8 i put it into the 5.7x's just playing with setup during mid summer(110 deg fl weather).i sprayed it shortly after and i never looked back.im sure it would step into the 5.6x's easily now with weather cooling down.my 60ft's are usually 1.33-34 bike sits at 69 inches with the 16-41 gear.i figured the 1/8 mile split would suffer when i ran 1/4 because of the tall gear i had to run but the bike actually went faster
zx-sik-r is offline
post #8 of 10 Old 10-06-2010, 06:53 PM
gazx10's Avatar
flying
siker, thats fast. air fixin to get cool and crisp, wouldnt surprise me if u go 30's in the eigth and quarter. good work, good riding cody.
gazx10 is offline
post #9 of 10 Old 10-06-2010, 08:01 PM Thread Starter
zx-sik-r's Avatar
thanks bud i should trap some high 5.3x's fri night.starting to see bearing matter in the oil pan so i either gota get new bearings in it soon or build my other engine.im truly addicted to nitrous but its hell on a engine.im toying around with buiding a stoke bore(cp piston/crowler rod) setup and putting a 75shot to it so i dont have to re-port the head.im already in need of a lockup because my setup doesnt mph like it should.its always something.keep me informed of when you get that rocket of yours done so i can come watch it get down the track
zx-sik-r is offline
post #10 of 10 Old 10-06-2010, 08:13 PM
NinjeR's Avatar
I so want to run those kinds of times!
NinjeR is offline
8th mile/1/4 mile times and mods rated zx Strip 14 06-29-2011 08:39 AM
mojave mile, march-6/the fastest mile in the west CHARLIEZX600 General Motorcycle Discussions 9 03-08-2010 11:40 PM
*NWS* - It finally has finally happened , sunglasses are bigger than bikinis....: mr_honez Adult Content - Photos / Videos - N.W.S. 22 01-19-2009 06:44 PM
Heads UP Quarter Mile 1/4 mile times olec4 Race and Stunt 9 03-03-2006 06:52 AM
How would you like to run the mile...not quarter mile! ZXMustang The Out House 18 01-19-2006 10:49 AM
