How much does a strap by itself help? numbers inside - Kawasaki ZX-10R.net
post #1 of 9 Old 06-20-2009, 08:09 PM Thread Starter
05 suzuki sv1000
11.191
121.22
1.88 60ft
half track
7.25 at 100.67
If I ''strapped'' down the front end, what would be a realistic time, as it was impossible for me to go wot in first.... Is it ok to strap the front without doing any other mods to the chassis? TIA
06wreckedzx10 is offline
post #2 of 9 Old 06-20-2009, 09:13 PM
codyc_13's Avatar
if you are trying to get into the 10's. Then yes i think a strap will do it for you, no other mods required. unless you have radial mounted calipers then you will need brackets.
Sponsored by:
Vaughan Racing
Synthetic Shield
Moline Bar
codyc_13 is offline
post #3 of 9 Old 06-21-2009, 12:12 AM Thread Starter
Cool, im gonna grab one off ebay and head back to the track.
How much travel do you leave in the suspension?
How low do most people drop the rear? I also see they make fixed dogbones in the rear for cheap. 1 2 or 3 inch...
post #4 of 9 Old 06-25-2009, 07:18 AM
Ruthless Racing's Avatar
Images: 9
A strap is a must if drag racing a bike
Kenny Poppell
AMA Dragbike SuperSport #1000
2007 AMA Dragbike 1000SS National Champion
2007 1000SS 1/8th ET Record Holder 5.967
Best 1/[email protected] Best 1/[email protected] Stock Wheelbase
Special Thanks:
Performance Psycle
Richies Tires
http://www.XXXRacingFuel.com
http://www.SuperbikeSpecialties.com
http://www.Tsukigi.com
http://www.CycleConceptsRacing.com
http://www.myspace.com/ruthlessracing1
Ruthless Racing is offline
post #5 of 9 Old 06-25-2009, 07:59 AM
Omofo's Avatar
That's a respectable time IMO. Used to have a sv650 BTW.
Omofo is offline
post #6 of 9 Old 06-25-2009, 10:41 AM
Slow Poke
bgmagma10's Avatar
yes a strap is the cheapest way to be a little quicker in the 1/4
bgmagma10 is offline
post #7 of 9 Old 06-25-2009, 10:46 AM
chogue's Avatar
Images: 13
60ft times are pretty good, i'd say you would be awful close to hitting 10's, lowering across the board will def put you in the 10.9 range. figure out your gearing also, are you having to make another shift late in the track, or are you crossing the line after you have dropped off power, sometimes one or two teeth on a back sproket can make a pretty decent difference.
for instance my buddy on his TLR went up 2 teeth on his back sproket and became slower because he had to make one more shift even though his 1/8 mile time imprved.
chogue is offline
post #8 of 9 Old 06-25-2009, 03:12 PM
Crank it down as hard as you can - unless you're the incredible hulk, there will still be enough suspension travel.
Patrick is offline
post #9 of 9 Old 06-26-2009, 08:28 PM
bluedevil's Avatar
Best advice yet when I first started with a PURE stock bike other than gearing on my 10R the strap plus lowering helps concentrate on other things like Ruthless will tell you that takes practice. I believe on my experimental Black ZX10R bike I did 10.9s strapped(my first time only after strapping EVER hitting the 10s) and a few visits later 10.3s on my Bloo bike... BAM I am in....that's the key my gearing as well I am at the limit in 4th gear(but no loss of power) on a pure stock bike going through the traps(145mph+) so after that happened it was just practice to get quick off the line because I never had to worry about the back half or create any slow down(changing gears by foot late) as my time slips show that
bluedevil is offline
2004 - 2005 Kawasaki ZX-10R sales numbers / production numbers? RichTJ99 The ZX-10R 6 05-09-2012 09:25 PM
Front End Strap OneSLOW10 Race and Stunt 2 04-03-2008 06:07 PM
If you Strap Your bike... bkkninja Strip 19 08-14-2007 09:46 PM
Too Strap or not Too strap???? bluedevil Race and Stunt 7 08-19-2005 07:08 AM
Anyone wearing a strap-on? litrejunkie The Out House 7 07-09-2005 07:56 AM
