Gen 4: 2011-2015 how to improve 1/8 times?? - Kawasaki ZX-10R.net
post #1 of 4 Old 07-27-2015, 01:12 PM Thread Starter
First time at the drag strip since I got my 4th gen, SWB with full exhaust and a flash. First time out launching this bike, how can I improve? I know I can get my 60ft lower but I feel like where I was lacking was taking to long to hit wot. Any tips???
I did have a strap, and stock height
1/8 6.66
60 1.77
mph 120
I tried launching at different RPMs, but my best runs I was aroung 7500-8000
1upmoto is offline
post #2 of 4 Old 07-27-2015, 01:22 PM
TechX's Avatar
try adding lowering links on the rear and experiment with tire pressures to see if it will improve your sixty foot.
TechX is offline
post #3 of 4 Old 07-27-2015, 02:16 PM
PatrickG's Avatar
Images: 15
What is your gearing? And the bike should be lowered in the rear also.
2005 ZX-10R Akrapovic Ti Evo 2 w/CF LOR can, PC3 with custom map, Factory Pro velocity stacks
2009 ZX-10r Full Gen4 Brock's SS exhaust with CF 14" can, PC3, Secondary Butterflies Removed, Kawasaki Race Exhaust Cam, My Own TRE, Degreed Cams 109/108
2011 zx10r Lower'd 2" Frt & Rear, Stretched 8", Graves CF slipon, GUHL Flashed ECU
PatrickG is offline
post #4 of 4 Old 07-27-2015, 07:09 PM
Blue08's Avatar
Location: Mentor on the Lake, Ohio/Broke at a dragstrip
Yes. What was already said above... You can get some lowering bones and just lower it when you go to the track, then raise it back up when your done if you want. Only takes maybe 20 minutes. Definitely add some gear but the biggest thing that will improve your times Is seat time. How many passes have you made? Just get use to the clutch and keep practicing
65, pos
8.67 @ 154mph
Blue08 is offline
Looking To Improve Va zx10r The ZX-10R 4 07-09-2007 02:49 PM
Improve brakes!!! Musikkant54 Performance and Tech 23 05-02-2007 03:15 PM
