Hitting the Strip Looking for Advice - Kawasaki ZX-10R.net
post #1 of 9 Old 08-20-2010, 07:48 AM Thread Starter
Postwhore with an 04
bcm0018's Avatar
I'm taking my gen1 to drag strip tonight and looking for all and any pointers and tips. Its SWB and stock height so besides launching I think keeping the front down is going to be the biggest challenge. I went once before and only made 3 passes neither of which was all out cause I didnt have a full suit but I do now. 9's would be awesome but I doubt it. I think my bike can do it but I dont think I'm skilled enough.
Thanks in advance!
If anyone wants to know here is the mod list:
megacycle cams w/ springs and retainers
Thin HG
PC3 and IM with dyno tune
ceramic trans bearings
full beet nassert exhaust
ohlins shock and R/T forks
520 chain -1F
1/6th throttle
sato rearsets GP shift
And some weight reduction (speedcell bat, CF etc)
There is more but thats what I can think could have an impact on my 1/4 time.
Originally Posted by k_p_m View Post
PS. This is by far the most epic fail I have ever laid my eyes on. Holes in the ECU guy and "yut ugh" guy and NOS energy drink guy are all so relieved you came along and destroyed their epic failness with your damn speed holes in the frame.
IBSR
bcm0018 is offline
post #2 of 9 Old 08-20-2010, 08:34 AM
Licensed Dist of HaterAde
TMY10ER's Avatar
Drop the front end about 10mm if you don't have it strapped already?
then give em' hell man and let us know the results!!
Take a risk, and you may lose. Never risk, and you will always lose.
TMY10ER is offline
post #3 of 9 Old 08-20-2010, 08:52 AM Thread Starter
bcm0018's Avatar
No strap, I'll see if I have time to drop the front before I head out. Thanks!!
IBSR
bcm0018 is offline
post #4 of 9 Old 08-20-2010, 09:25 AM
TMY10ER's Avatar
No worries man and just loosening those 8 bolts (total) on the upper and lower triples to drop the trees down a bit will make quite a bit of difference in keeping or i should say in "helping" keep the front end down bud.
TMY10ER is offline
post #5 of 9 Old 08-20-2010, 02:30 PM
zx racer's Avatar
def pick up a strap if you can they help out a ton, also slide the forks up about a inch if you havent already, takes only 30 min to do and it also helps, good luck and let us know wat she runs.
05 ZX-10R SWB.
zx racer is offline
post #6 of 9 Old 08-22-2010, 08:49 PM
zx-sik-r's Avatar
sounds like you have some good parts to work with.dragracing isnt anything somebody can tell you how to do,you just gota get out and ride that bike every chance you get and every pass you will learn sumtin....riding a swb will give you one hell of a clutch hand.keep us posted!
zx-sik-r is offline
post #7 of 9 Old 08-23-2010, 11:21 AM Thread Starter
bcm0018's Avatar
10 for me I have attack clip ons but I know what you mean.
I've been meaing to get lowering links and a strap for when I want to hit the strip but most my money is going into a different toy right now. I'll have to start looking around for one though.
I'm just a HP junkie and teh dragstrip is a lot closer than the local track for a trackday is.
Didnt get a chance to run. They actually had a professional event so I just turned around and went home :( I'll try again soon!!
IBSR
bcm0018 is offline
post #8 of 9 Old 08-23-2010, 11:42 AM
dirt ninja's Avatar
Images: 9
bcm...You should be able to lower the rear end of your bike with your ohlins shock... No need to buy lowering links...
Marchesini Magnesiums,Nassert beet,kawi cam,.45 headgasket,DJ PC/Ig.M/QS,velocity stacks,bmc race,gipro,sato rearsets,helibars,throttlemeisters,pazzo shorties,speedohealer,520 renthal sprockets,penske 8393 double clicker,traxxion dynamic springs,scotts stabilizer,lsl frame sliders,cox radiator guard,powerbronze hugger,puig DB,solo seat cover,Valentine1,dual low beam projectors,55w.hids, brembo superbike rotors,Goodridge superbike lines,nissin calipers and rizoma mirrors,mda123 battery.
dirt ninja is offline
post #9 of 9 Old 08-23-2010, 12:21 PM Thread Starter
bcm0018's Avatar
Good point! I'm not very good with suspension setup so it didnt cross my mind, time to bust out the instructions.
IBSR
bcm0018 is offline
10 hitting on 3 cylinders broken arrow Performance and Tech 9 04-02-2010 12:49 AM
Imagine hitting this on your 10 gomer The Out House 13 02-19-2010 10:03 PM
advice for first time down the strip? kiwifruit Race and Stunt 18 06-30-2007 08:03 PM
Penguin hitting sabersaw30 Pictures and Videos 11 05-14-2005 04:48 PM
Hitting Rev Limiter..... SteveNYC1 Performance and Tech 37 05-12-2005 09:12 PM
