help on welding clutch basket mod plz - Kawasaki ZX-10R.net
post #1 of 8 Old 05-04-2010, 12:03 AM Thread Starter
jrzx10r's Avatar
Images: 9
i keep hearing differnt on this. can someone tell me does this need to be done on the first gens or no i have a 05 and am putting clutches in it tomorrow and have the basket off ready to take and get welded but while i was trying to find pics of 1 done tonight i have read someplaces that it dosent need to be done on the 1st gens. and i really dont want to get it welded on if it dont need it. so what is it weld it or dont weld it? thx guys
jrzx10r is offline
post #2 of 8 Old 05-04-2010, 07:50 PM
07ZX10RJoe's Avatar
I don't know about the first gens. But since you already have it off it's better safe then sorry. That's just the way I would look at it.
07ZX10RJoe is offline
post #3 of 8 Old 05-05-2010, 08:45 AM Thread Starter
jrzx10r's Avatar
Images: 9
ya that is the way i looked at it i went ahead and had it welded and took pics sence i couldnt find any on here or anywhere else i will post them later when i get a chace. cant wait to get it out and try it out they have been slipping bad sence i streched it cant wait to see what it really has in it.
jrzx10r is offline
post #4 of 8 Old 05-05-2010, 06:47 PM Thread Starter
jrzx10r's Avatar
Images: 9
pics
heres the pics of it taking apart and of it welded
jrzx10r is offline
post #5 of 8 Old 05-05-2010, 09:50 PM
07ZX10RJoe's Avatar
Yeah I would have taken pics of mine when I did it but forgot about it untill after I put everything back together.
post #6 of 8 Old 05-27-2010, 06:23 PM
tone.r's Avatar
what does this mod do, or help?
Tone.R {checkmate}
Do what makes u happy whatever it is.....Roberson Racing
tone.r is offline
post #7 of 8 Old 05-28-2010, 09:41 PM
gazx10's Avatar
better to fine wire weld all the way around all three rivets, stronger. also, loose, rattling springs can be fixed, carefully tap tangs down not binding spring until spring no longer rattles. dont just beat it down tight, the spring must float between the backing plate and hub absorbing shock and transferring power . thats their purpose. just enough to eliminate rattling. a good welder can spot weld the tang corners , not welding the spring or binding it. engine power is trying to push these springs outward, through the metal plate, bending the tangs out. if you bang your ten, most do, this is a must do. sloppy, rattling springs are the first sign of a problem that progresses to your hub coming thru cover or cases. you may see hairline cracks in the corner of the tangs from stress where the tang has been stretched, this is where you spot tack the tangs repairing them also. if you hear your clutch rattling at idle, this is your problem. loose baskets are not uncommon, they are common, i do both to my bikes, good preventive maintenence and disaster insurance.
gazx10 is offline
post #8 of 8 Old 05-29-2010, 11:20 PM
07ZX10RJoe's Avatar
Great info Gazx10. My bike is down at the moment due to a broken chain last week so, I'll be doing some maintenance while I can't ride it.
08 Clutch Basket Swag The ZX-10R 18 09-04-2017 06:36 AM
help plz welding the bottons/basket on the 10s jrzx10r Strip 22 05-05-2010 06:54 PM
Clutch basket or something else??? Crazi The ZX-10R 1 04-19-2010 06:31 PM
06/07 ZX-10 clutch basket ?? WRECKSHOP The ZX-10R 0 05-26-2009 05:14 PM
