help plz welding the bottons/basket on the 10s - Kawasaki ZX-10R.net
post #1 of 23 Old 02-22-2010, 08:30 PM Thread Starter
jrzx10r's Avatar
Images: 9
i have read somewhere someone said something about welding the bottons/basket on the 10s can someone explane this for me plz or send me a link that explanes it . that would be very helpful and thx i also want to know witch gen they were talking about having to do do this on
jrzx10r is offline
post #2 of 23 Old 02-22-2010, 08:35 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
Have ya searched it? if so and no help then i'm sure someone on here will have the info you seek young jedi.....
TMY10ER is offline
post #3 of 23 Old 02-22-2010, 08:38 PM Thread Starter
jrzx10r's Avatar
Images: 9
ya i have and had no luck
jrzx10r is offline
post #4 of 23 Old 02-24-2010, 01:24 AM
WRECKSHOP's Avatar
You have to weld the rivets on the back of the clutch basket so that none of them either snaps off or pushes out its holes. I know that this mod is directly related to the 04-07 models. Have no idea if this mod needs to be done to the 08-2010 models. I think that they all have the same exact clutch basket in them. However, i could be wrong but i do think so!!! There are three dark colored rivets on the very back of the clutch basket that needs to be welded if you are going to race any of the ZX-10R's. Especially if your Dragracing it !!! If one of the rivets back out then it can cause severe damage to your engine. Falicon welds them perfectly and precise.
WRECKSHOP is offline
post #5 of 23 Old 02-24-2010, 06:28 AM Thread Starter
jrzx10r's Avatar
Images: 9
thx very much that helped alot i drag 2 bikes a 05 and a 07 guess i need to do this been lucky so far i guess. is there any pics of this anywhere if so can u get me a link i have looked everywhere cant find anything on it. thx again u have been very help full
jrzx10r is offline
post #6 of 23 Old 02-24-2010, 08:07 AM
redline659's Avatar
Pull the outter basket out and flip it over. You will three big round rivet heads. Have someone tig weld them to the primary gear which is the big gear they are already holding down.
If you need any help you can PM me and I will send you pictures
redline659 is offline
post #7 of 23 Old 02-24-2010, 01:25 PM
I thought this was only for NOS...
06green is offline
post #8 of 23 Old 02-28-2010, 07:39 PM Thread Starter
jrzx10r's Avatar
Images: 9
yup
jrzx10r is offline
post #9 of 23 Old 03-29-2010, 10:44 PM
07ZX10RJoe's Avatar
please post pics. I would like to see exactly what I'm after before tearing down.
07ZX10RJoe is offline
post #10 of 23 Old 04-09-2010, 03:52 PM
ok, i did the weld on both of my zx10r. just did another tear down because was hearing noise coming from the clutch basket. after doing my inspection notice that 4 out of the 8 spring on the back side of the basket was loose and 2 was grinding against the casing. so purchase another one off ebay to replace it and once I got the basket in today. that basket have 4 out of the 8 springs on the back side of the basket loose and 2 was grinding the against the casing. well you may say this is normal then, but i dont think so, because the first basket that i blow was making the same noise. i dont think it normal for another part to be rubbing each other in the motor and shows the sign of rubbing.
so have anyone esle have this problem or heard noise in the clutch basket.
benzx7r is offline
Welding Question? chuce4285 The ZX-10R 3 03-13-2009 12:55 PM
welding extensions leZx10 The ZX-10R 2 12-25-2008 06:40 AM
Plastic Welding? jdm123 The ZX-10R 13 12-11-2008 11:29 PM
Welding Titanium roland5color Performance and Tech 6 06-28-2008 04:05 PM
welding titanium scottymizt The ZX-10R 17 01-07-2005 03:58 PM
