Hays Lock up - Kawasaki ZX-10R.net
post #1 of 17 Old 06-26-2013, 11:38 AM Thread Starter
Darmentle's Avatar
Hays Lock up
Hey is anyone running this? Also does it come with everything you need to install it.
http://www.haysmachineworks.com/shopping/?p=406
07 zx10
DDM Hid Kit 8k
K&N Air Filter
Velocity Turbo kit
Evil Swing Arm
Gen 3 Motor
PC3
Darmentle is offline
post #2 of 17 Old 06-26-2013, 11:50 AM
TechX's Avatar
Lock up
Haven't hear much about Hays. I was using an MTC lockup in my Kawi. Loved it.
TechX is offline
post #3 of 17 Old 06-26-2013, 06:52 PM Thread Starter
Darmentle's Avatar
he doesn't make that clutch anymore he said sucks
07 zx10
DDM Hid Kit 8k
K&N Air Filter
Velocity Turbo kit
Evil Swing Arm
Gen 3 Motor
PC3
post #4 of 17 Old 06-26-2013, 07:03 PM Thread Starter
Darmentle's Avatar
MTC doesn't make either anymore damn . anyone know where to get a good deal on one?
07 zx10
DDM Hid Kit 8k
K&N Air Filter
Velocity Turbo kit
Evil Swing Arm
Gen 3 Motor
PC3
post #5 of 17 Old 07-06-2013, 11:25 AM
matt d's Avatar
Call up Spencer Cycle. Doug has ZX10 lockups in stock. Tell him Matt D from Chicago sent you.
68" 2011 ZX10
matt d is offline
post #6 of 17 Old 07-06-2013, 03:27 PM
Slow Poke
bgmagma10's Avatar
Does he have just a single stage or multi only?
bgmagma10 is offline
post #7 of 17 Old 07-06-2013, 11:45 PM
matt d's Avatar
Last time I checked with him, it was the Hay's convertible kit. Which should have both, as well as the slider option. I know Tim carries the super slider in stock at Hay's.
matt d is offline
post #8 of 17 Old 07-07-2013, 08:57 AM
Blue08's Avatar
Location: Mentor on the Lake, Ohio/Broke at a dragstrip
noob question but what exactly is the difcerence between thee and the oem?
65, pos
8.67 @ 154mph
Blue08 is offline
post #9 of 17 Old 07-07-2013, 09:14 AM
Slow Poke
bgmagma10's Avatar
God they're just so damn expensive!!!
post #10 of 17 Old 07-07-2013, 09:16 AM
Slow Poke
bgmagma10's Avatar
More or less the convertible clutch makes it to where you can either use your clutch lever or not have to at all. You can set it up as a lockup and still use your clutch lever off the line and the slider option makes it to where you don't use your lever at all. You have a set rpm that your clutch engages and you just use your throttle and the clutch does all the slipping for you.
hays t3 clutch sweetride10r Performance and Tech 1 01-15-2011 11:14 PM
F/S 06 ignition lock and trunck lock $100 obo cMac Parts, Gear and Accessories 0 04-28-2010 11:39 PM
hays convertible clutch brickman Strip 9 10-12-2009 01:38 AM
lock to Lock tank Slap! Tech5 The ZX-10R 43 09-06-2009 03:15 PM
Installed lock kit fine but stuck on seat lock djr33 The ZX-10R 1 08-11-2009 12:20 AM
