GPR settings on drag bike - Kawasaki ZX-10R.net
post #1 of 11 Old 03-03-2009, 03:55 PM Thread Starter
10R_Havens's Avatar
Just curious what setting everyone is running on their GPR or similar type steering dampener at the strip.
I noticed my setting was pretty low (2) and was curious if I could benefit from turning it up a few adjustments?
10R_Havens is offline
post #2 of 11 Old 03-03-2009, 04:00 PM
k_p_m's Avatar
I had mine at 4 for those first gear shakes....
k_p_m is offline
post #3 of 11 Old 03-03-2009, 04:01 PM Thread Starter
10R_Havens's Avatar
I guess I should turn it up a bit then?
What kind of problems would I experience if I put it at like "6" or max dampening?
Pretty much just riding straight, so that would help, correct?
post #4 of 11 Old 03-03-2009, 04:03 PM
Shorty's Performance
madnessracing's Avatar
turn it all the way!!
madnessracing is offline
post #5 of 11 Old 03-03-2009, 04:03 PM
k_p_m's Avatar
I would assume, I freaked out once at 1-2 so i turned it up and never noticed an issue
k_p_m is offline
post #6 of 11 Old 03-03-2009, 04:12 PM Thread Starter
10R_Havens's Avatar
Suppose if I can ride it low/mid 9's at 2, it should be a bit easier at 6!
post #7 of 11 Old 03-04-2009, 07:02 PM
bluedevil's Avatar
I don't have a GPR but a Scotts and before I pull up to the line I turn all the way tight....right after I finish I pop my head up from the double bubble and turn it out soft to make the slow turn out. I have been doing it this way for years and never had a high speed wobble or mishap.
bluedevil is offline
post #8 of 11 Old 03-04-2009, 10:40 PM
tank zx10r's Avatar
Images: 52
4 1/2
R.I.P Shannon T. Hightower July 29, 1971 August 4, 2007
All Kawasakis aren't created equal
tank zx10r is offline
post #9 of 11 Old 03-04-2009, 11:04 PM Thread Starter
10R_Havens's Avatar
Originally Posted by tank zx10r View Post
4 1/2
Why 4 1/2?!
post #10 of 11 Old 03-21-2009, 10:23 PM
cueman's Avatar
I set mine between 4 and 6 most time at 6
04 ZX10 muzzy turbo,ported and polished head,carpenter valve springs and valves,kaw race cam,walbro fuel pump,begi fmu,mps airshifter,pcIII and ignition module,strectched 10 over,galfer brake lines,530 ek drag chain,16 front sprocket 45 rear sprocket,gpr dampner,modded clutch basket
cueman is offline
Drag Bike ZXGREENMACHINE Pictures and Videos 2 03-14-2007 01:13 PM
Drag Bike BryanB The Out House 10 07-25-2006 10:52 PM
Any one got a drag bike? Loweredskulls Performance and Tech 4 06-19-2006 11:00 PM
drag bike eric Race and Stunt 14 06-28-2005 07:41 PM
Bike Drag Mag? BeepeR Race and Stunt 0 03-26-2005 07:54 PM
