GIpro/TRE question, custom mapping - Kawasaki ZX-10R.net
post #1 of 5 Old 07-16-2008, 11:43 PM Thread Starter
JUPJON's Avatar
Location: Fargo, ND (only about 6 month riding season unfortunatly)
Images: 15
Just wondering if anyone here has tested or made a noticeable difference on 10s w/Gipro and TRE and customer map PC3. Does the TRE even do anything or effective when you have a custom mapped commander? Going to the strip this weekend and wondering what setting I should try the TRE on or just leave it off? Help me out, guys I haven't had enough track time to test this out much. I tried last year leaving it off and then turned it on setting 3 or 4 and my time slips were almost the same but it did seem to run slightly different. Thanks for any info!
98% of all Harleys ever sold are still on the road. The other 2% made it home.
JUPJON is offline
post #2 of 5 Old 07-17-2008, 12:11 AM
bluedevil's Avatar
Wont make a diff. read my thread:
https://zx-10r.net/forum/showthread.php?t=57171
in that run to get 9s I always had a switch to turn on the TRE but in high RPMs it's useless and no gain in drag racing a 10R as you will be at High RPMs even at start for it not to help....it's for the mountains for on and off transitions and no HP gain.
bloo
bluedevil is offline
post #3 of 5 Old 07-17-2008, 12:18 AM Thread Starter
JUPJON's Avatar
Images: 15
Thats kinda what I was thinkin, I'll just leave it 'off' then. another member told me he was running his best times(9s) w/tre on and a similar setup as me. thanks bloo.
JUPJON is offline
post #4 of 5 Old 07-17-2008, 12:25 AM
bluedevil's Avatar
no problem, have a good time at the track.
post #5 of 5 Old 07-17-2008, 12:31 AM Thread Starter
JUPJON's Avatar
Images: 15
I always do, can go all out and not have to worry about the police or other uncertainties. I'll post my best slip if I find it is worth posting
JUPJON is offline
Need Help with 06 Mapping ninja japan Performance and Tech 1 03-02-2008 03:59 AM
Custom made gp exhaust question Jimsmowen Performance and Tech 5 10-22-2007 07:11 AM
Mapping Question Ice06 Performance and Tech 2 02-27-2007 12:14 PM
question on custom/any PCIII map??? on1whl Performance and Tech 2 08-08-2006 06:34 AM
Custom Mapping Dyno Sheets DB's ZX10R Performance and Tech 4 08-15-2005 08:43 PM
