Gen 2 clutch chatter? - Kawasaki ZX-10R.net
post #1 of 14 Old 07-23-2012, 07:52 AM Thread Starter
DZZNUTS's Avatar
Ok ok ok,elbow its been beat to death on here, but I just want to know what works to help elim this. Gen 1 clutch, judder spring, or what? I wanna offer today so advise asap is preffered...Clutch is fine just sucks to launch!
DZZNUTS is offline
post #2 of 14 Old 07-23-2012, 07:53 AM Thread Starter
DZZNUTS's Avatar
Also phone won't allow me to search....
DZZNUTS is offline
post #3 of 14 Old 07-23-2012, 08:40 AM
zx racer's Avatar
alot of gen2-gen3 guys are converting over to the gen1 clutch pak bc its much better... you wanna get fibers, steels and judder spring for a gen1... that should take care of the bucking, clutch chatter your hearing.
05 ZX-10R SWB.
zx racer is online now
post #4 of 14 Old 07-23-2012, 08:58 AM
Bmore-stunter's Avatar
I have the same problem what is the judder spring
Bmore-stunter is offline
post #5 of 14 Old 07-23-2012, 09:38 AM Thread Starter
DZZNUTS's Avatar
So just call concept and get the whole "pak"? Are ths steels and friction plates that much different?
DZZNUTS is offline
post #6 of 14 Old 07-23-2012, 10:00 AM
zx racer's Avatar
judder spring is the 2 steel plates thats together... it helps eliminate the noise you hear when launching.
yep tell em you want a clutch pak for a gen1... once you go gen1 you want wanna go back
05 ZX-10R SWB.
post #7 of 14 Old 07-23-2012, 01:48 PM Thread Starter
DZZNUTS's Avatar
They must be busy on mondays... Called 3 times, no answer
DZZNUTS is offline
post #8 of 14 Old 07-23-2012, 07:00 PM Thread Starter
DZZNUTS's Avatar
What you pay for the pak?
DZZNUTS is offline
post #9 of 14 Old 07-23-2012, 07:10 PM
zx racer's Avatar
pm sent
05 ZX-10R SWB.
post #10 of 14 Old 07-23-2012, 08:14 PM
Post Whore
-Op-'s Avatar
judder spring is 2 steels that basially are sprung together to put pressure against the entire pack to ensure everything is together.
-Op- is offline
Gen 4: clutch chatter on new 2012 dtag13 The ZX-10R 5 06-15-2012 05:05 PM
2012 clutch chatter dtag13 The ZX-10R 7 06-15-2012 05:37 AM
clutch ? about chatter.... DZZNUTS Strip 12 01-13-2012 11:09 AM
Clutch has started to chatter tjunkie The ZX-10R 8 08-11-2011 11:31 AM
Chatter Box BigDally The Out House 8 09-21-2006 01:00 AM
