Gen 1 Engine Case Markings - Kawasaki ZX-10R.net
post #1 of 3 Old 05-31-2012, 06:12 PM Thread Starter
Can anyone post a pic or describe where can I find the engine case marking. Are there marking on the top and bottom cases ?
I'm running into clearance issues on my re build. The bike had a 4mil crank in it and i replaced the crank with a stock crank from another bike. Went to mic the main journals and we are tight on clearance.
thanks in advance
shane843 is offline
post #2 of 3 Old 06-02-2012, 06:57 AM
brijesh600's Avatar
some one correct me if i am wrong, but you need to buy top and bottom cases as a set, as they are machined together. there is the no hole, one hole, and two hole designation for the cases and there is also a mark on the crank, certain crankshaft work with certain hole designation crankcases.
here is my thread on the same issue:
https://www.zx-10r.net/forum/showthread.php?t=107845
brijesh600 is offline
post #3 of 3 Old 06-03-2012, 12:21 AM
Gen2 Ripper
neverendingmods's Avatar
Correct. Must use cases from a matching set. Can not mix case halves. Uncertain if that is your problem or not.
07-ZX10R-SOLD
, 1/5th insert, -1/+5,comp werkes decatted,PC3+multi-hub,piperX,30 dry shot,2custom maps,Ballistic EVO2,Pazzo shorties,SATO rearsets,HealTech,ZG Corsa,EBC XC Gen3 rotors,Vesrah pads, SS lines, Gen3 calipers, etc and stretched 8" so it won't flip
05-ZRX1200R-sold
04-KX500-sold
1975 RD350-garage queen
neverendingmods is offline
Engine markings keithk Performance and Tech 2 10-23-2010 04:44 PM
zx-10 case markings Vince10R Performance and Tech 4 05-11-2007 12:53 PM
engine case covers coastiepete The ZX-10R 0 04-21-2007 04:46 PM
WTB: 04/05 ZX-10R engine case CountDokoo Wanted: Buy or Trade 1 03-14-2007 01:31 AM
crack in engine case zx12r The ZX-10R 11 01-25-2006 01:32 PM
