Gen 2: 2006-2007 Gears not engadging - Kawasaki ZX-10R.net
post #1 of 9 Old 05-28-2014, 05:57 AM Thread Starter
Nitrosaki's Avatar
Gears not engadging
Hi Guys
Ran this weekend the desert drag wars and had lots and lots of problems with my gearing. Struggled to shift from 1st to 2nd. Then approaching the line in 4th it felt like the bike is cutting the ignition
Any suggestions?
Nitrosaki is offline
post #2 of 9 Old 05-28-2014, 07:14 AM
SkyDork's Avatar
Sounds like you've got tranny issues. But I'm not sure as your description is a bit vague. What is wrong with the 1-2 shift? Hard to get into gear or popping out of gear.
The other issue sounds like the gears aren't fully mating and the gear dogs are popping in and out of the slots.
If I was to speculate, you've got shift fork and/or drum damage. Both require opening the motor go replacement.
#WordCrimes
SkyDork is offline
post #3 of 9 Old 05-30-2014, 06:02 PM Thread Starter
Nitrosaki's Avatar
I had the problem before and found two out of the three shift forks bent and to top it off my second gear's dogs were completely worn out. I replaced all new. Now, i am running both dynojets quickshifter as well as the mps air shifter. What is the possibilty that my air shifter is causing this to keep happening? Could it also maybe be that the nitros is coming in too hard?
post #4 of 9 Old 05-30-2014, 06:04 PM Thread Starter
Nitrosaki's Avatar
Basically just struggling to shift into second but not popping out.
post #5 of 9 Old 05-30-2014, 06:08 PM
SkyDork's Avatar
Very likely that is the issue if the air shifter is too hard too soon and not waiting for the fuel to get interrupted fully. This is part of the reason I'm not a fan of the Dynojet quick shifter. It cuts fuel at the injectors, which takes a small amount of time (milliseconds) for the interruption to travel down the intake runners and for the engine to respond. I feel that the ignition interrupt is more immediate.
With the kill times set to milliseconds for the shift to occur, the tranny might not be fully unloaded before the air shifter attempts to change gears.
#WordCrimes
SkyDork is offline
post #6 of 9 Old 05-31-2014, 11:00 AM
gazx10's Avatar
talk to some of your fellow racers. if airshifting, will have problems if still spinning sand or asphat as I suspect u are on 1-2 shift.
gazx10 is offline
post #7 of 9 Old 05-31-2014, 03:21 PM Thread Starter
Nitrosaki's Avatar
Do you suggest I set the kill time for a longer period and try again? What is strange to me is that I never had the problem before I changed from slick to semi slick. Another thing, what do you guys think about this pair valve being blocked off?
post #8 of 9 Old 05-31-2014, 10:10 PM
thundercoupe9's Avatar
get a shifter set up that lets you adjust delays, that way your ram isn't trying to shift before the engine unloads the trans, otherwise it will continue to break parts. Here is an example of what I am using, it kills the engine and then after a set delay shifts.
thundercoupe9 is offline
post #9 of 9 Old 06-01-2014, 01:32 PM Thread Starter
Nitrosaki's Avatar
Thanx guys.
Appreciate the help
new gears sam_b03 The ZX-10R 0 08-03-2013 12:41 AM
gears mposey22 Strip 10 09-17-2012 08:04 AM
Gears?? knej29642 The ZX-10R 7 04-16-2012 11:52 PM
06 cam gears stretched10R Performance and Tech 4 03-11-2011 11:39 PM
chain and gears fbdr24 The ZX-10R 34 07-24-2004 04:09 AM
