gears - Kawasaki ZX-10R.net
post #1 of 11 Old 09-16-2012, 05:56 PM Thread Starter
mposey22's Avatar
gears
I currently run a 16/47 on my 1/8th mile bike, Im switching to a 15/45 this week and gonna test that. will that be enough gear to get through the 1/4 mile. I run 1/8th mile weekly but attend 1/4 mile events monthly. anyone run a 15/45 in the 1/4?
mposey22 is offline
post #2 of 11 Old 09-16-2012, 06:11 PM
Shift_Nashville's Avatar
I'd ask cookmaster30, or pm him...he runs some pretty wild Times in the 1/4 and has tried many different gearing combos
i could give two shits if you were taking a bubble bath in applesauce being fed grapes by lemurs with electrodes attached to your nipples in the bed of a semi truck, as long as you're not holding up traffic, go for it
Shift_Nashville is offline
post #3 of 11 Old 09-16-2012, 06:20 PM
Certified SLOW
nolaZX10's Avatar
Not enough info to answer whether it is enough gear for the 1/4. We need to know what your typical trap speeds are.
For reference, at 16/46 I was banging the limiter at 147 and your proposed 15/45 would hit the limiter at a slightly lower mph.
Best 1/4mi ET: 8.98 @ 147 (stock motor, no turbo/nitrous)
nolaZX10 is offline
post #4 of 11 Old 09-16-2012, 06:23 PM Thread Starter
mposey22's Avatar
quickest 1/8th mile so far is a 6.13 at 117mph. i know some run a 15 on the front so was gonna try that this week to run the 6.0 class.
mposey22 is offline
post #5 of 11 Old 09-16-2012, 06:34 PM Thread Starter
mposey22's Avatar
9.70s in the 1/4 at 138 to 140
16/47
mposey22 is offline
post #6 of 11 Old 09-16-2012, 08:17 PM
zx racer's Avatar
wat gear are you going the traps at now in the 1/8 ? this will further help us no if you will have enough or to much.
05 ZX-10R SWB.
zx racer is offline
post #7 of 11 Old 09-16-2012, 08:24 PM Thread Starter
mposey22's Avatar
just into 4th in the 1/8th
mposey22 is offline
post #8 of 11 Old 09-16-2012, 08:33 PM
zx racer's Avatar
ok you should be fine with 15/43 or 15/44... i believe 15/45 will be lil to much.
05 ZX-10R SWB.
zx racer is offline
post #9 of 11 Old 09-16-2012, 08:39 PM Thread Starter
mposey22's Avatar
would the 15/45 be good for the 1/8th. I have just about the same numbers as you in the 60 and the 330. but then end up about a 6.15 to 6.20 in the 1/8th Thats with the 16/47.
mposey22 is offline
post #10 of 11 Old 09-16-2012, 09:17 PM
zx racer's Avatar
15/45 will be a good gear for the 1/8 but youll probly run out of gear for 1/4. i run 15/41 and cross the 1/8 mile traps in top of 3rd gear and @62in she's a handfull you'll love the 15t man it woke my bike up like crazy
05 ZX-10R SWB.
zx racer is offline
Gears?? knej29642 The ZX-10R 7 04-16-2012 11:52 PM
06 cam gears stretched10R Performance and Tech 4 03-11-2011 11:39 PM
Whats gears for TWS etc Bigcat#44 Race and Stunt 4 10-12-2007 05:32 AM
Cam Gears... Bobster Performance and Tech 2 04-14-2005 10:45 AM
chain and gears fbdr24 The ZX-10R 34 07-24-2004 04:09 AM
