Gearing question - Kawasaki ZX-10R.net
post #1 of 13 Old 11-15-2010, 10:34 PM Thread Starter
mrbzx7's Avatar
Gearing question
Anyone tried 15/45 on a 3rd or any gen? The bike is stock slip on only and a 25 shot, @ 62.5 wheelbase. Has been 6.08 @ 125 on spray, trying to dip into 5's on motor, my current gearing is 16/45.
mrbzx7 is offline
post #2 of 13 Old 11-21-2010, 11:18 PM
whats you weight? ive been [email protected] on a stock motor 05 zx10r 15/42 setup with a 4 inch extension you should be more then capable of 5's im sure i can hit em with a 1.5 to 1.4 60...the 15t made a HUGE NIGHT A DAY difference out the hole compared to my 16t
seanc520 is offline
post #3 of 13 Old 11-22-2010, 12:04 AM
Licensed Dist of HaterAde
TMY10ER's Avatar
drop to a 16 tooth in the front and give it hell..................99.9% chance of smiles and happy times i'm sure!!
Take a risk, and you may lose. Never risk, and you will always lose.
TMY10ER is offline
post #4 of 13 Old 11-22-2010, 02:19 AM Thread Starter
mrbzx7's Avatar
I weigh 145 maybe 160 suited, and I running -1+4 sprockets. 6.22 is my best pass on motor. However my '60 and '330 where so so, I know it has more with my current setup. With that said I'm still in 1st gear untill just before the '330, this is why I wanna go to a 15t. Which would be -2+4 (15/45), stock was 17/41.
mrbzx7 is offline
post #5 of 13 Old 11-22-2010, 02:56 PM
put on a 15t and you will fall in love all over again with your bike
seanc520 is offline
post #6 of 13 Old 11-22-2010, 05:19 PM
15T will not majically drop ur times. U need practise. A full system/PC with no flies will help u out too..
06green is offline
post #7 of 13 Old 11-22-2010, 08:19 PM Thread Starter
mrbzx7's Avatar
I know there will be a learing curve when changing anything, but I do hope to see some 1.4 60's and high 3's @ the 330'. I'm gonna do it
mrbzx7 is offline
post #8 of 13 Old 11-22-2010, 08:44 PM
Certified SLOW
nolaZX10's Avatar
What chain are you running? Just curious, I've been trying to decide on whether to stick with 520 or 525 and have been contemplating 15T also. Just have been reading a lot of mixed reviews regarding the 15T, with some saying they had problems with it skipping and others not.
Best 1/4mi ET: 8.98 @ 147 (stock motor, no turbo/nitrous)
nolaZX10 is offline
post #9 of 13 Old 11-22-2010, 09:16 PM
Supercharged Mod
A bigger sprocket transmits the same torque to the shaft with less pull on the chain and each link has to turn through a smaller angle as it wraps over the sprocket. Beyond that, the only thing that matters is the overall drive ratio.
51/17 is the same drive ratio as 48/16 is the same drive ratio as 45/15, but 51/17 will put the least stress on the chain (and the least pull on the transmission output shaft and the least pull on the suspension and swingarm!) and 45/15 will have the most ...
The other thing to watch for is that with a small drive sprocket, sometimes the chain can rub on the swingarm guides, because it pulls the chain closer to the shaft.
GoFaster is offline
post #10 of 13 Old 11-22-2010, 09:53 PM
Post Whore
1killer1liter's Avatar
Images: 11
You also have to take into account weight. I do agree with what you're saying though. A 17t weighs more than a 16t or a 15t. And same goes out back. I want the best balance of weight and torque without damaging other things. Personally I wouldn't go smaller than a 16t front. If I need more, then I go bigger on the rear.
I live my life a quarter-pounder at a time. And for those 500 calories or more, im free. I need FRIESSSS! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didnt blow a seam on your nugget box.
1killer1liter is offline
strange gearing question ellis976 The ZX-10R 3 06-13-2010 12:06 AM
Another Gearing Question Justin Performance and Tech 14 11-27-2009 01:28 PM
GSXR600 gearing question Deer Elk Performance and Tech 7 08-01-2007 04:44 PM
Another Gearing Question Skip114 Performance and Tech 3 01-08-2007 12:28 AM
06 Gearing Question Skip114 Performance and Tech 1 01-05-2007 03:15 PM
