gearing problem - Kawasaki ZX-10R.net
post #1 of 10 Old 04-11-2011, 06:04 PM Thread Starter
gearing problem
so i think i got in a little over my head but not sure. bought a 09 zx10 last fall and ran it a couple times (ive been racing about 2 years now). this winter i put a full brocks short meg, pcv, and two step on it. i also lowered it 2 inches and have a strap for the front. i then went and put a 15 tooth sprocket on the front. i went to a test and tune this weekend and couldnt seem to keep it under control. should i be able too or should i jump up to a 16 or even back to stock. just looking for a little advice on where to set the 2 step and what to try
timmyriv is offline
post #2 of 10 Old 04-11-2011, 06:08 PM
Certified SLOW
nolaZX10's Avatar
If your SWB... -2 in the front is going to be hard to get keep the front end down. I don't know your weight, but on my Gen. 1 I ran -1 up front and it was about perfect. Front sprockets are cheap enough, buy a -1 and try that.
Best 1/4mi ET: 8.98 @ 147 (stock motor, no turbo/nitrous)
nolaZX10 is offline
post #3 of 10 Old 04-11-2011, 06:21 PM
mrbzx7's Avatar
Whats your weight and wheelbase also how big is rear sprocket?
mrbzx7 is offline
post #4 of 10 Old 04-11-2011, 06:43 PM
codyc_13's Avatar
-2 is approximately like going up 6 in the rear. Try -1 up front and if it isn't enough go +1 in the rear. I assume you are stock wheelbase?
Sponsored by:
Vaughan Racing
Synthetic Shield
Moline Bar
codyc_13 is offline
post #5 of 10 Old 04-11-2011, 07:22 PM
bama~guy's Avatar
i have an 08 im 200lbs stretched 8'', geared 15/45 and i love it, it may be that two step thing thats making it act crazy i wondered how much they help let me know please
bama~guy is offline
post #6 of 10 Old 04-11-2011, 07:27 PM
filthy phil's Avatar
i'm running -1 front, +1 rear, working out great on the street. but the shift light comes on at around indicated 174 mph
team FTP
Area p, zx14 nissins and mc
Riflemans 1/5. -1 +1 sprockets w/chrome ek zzz. galfer lines. K&n.,ultra custom black front fender // over 55k miles
filthy phil is offline
post #7 of 10 Old 04-11-2011, 08:49 PM
zx racer's Avatar
when i had a -2 sprocket on the front i was always lookin at the sky. i would stick a 16t on the front and do all your gearing changes to the rear. maybe go up +1 or 2 and see if that helps.
05 ZX-10R SWB.
zx racer is offline
post #8 of 10 Old 04-11-2011, 09:22 PM
strkd50's Avatar
The quickest run swb on my '08 was with 15/39 gearing. Very similar to if you went -1 +1 but with the added benefit of a little extra wheel base. Went 9.81 @ 150 on that pass
2012 ZX-14R
#228
strkd50 is offline
post #9 of 10 Old 04-11-2011, 09:30 PM Thread Starter
yes im swb have a stock rear sprocket and im about 220 lbs. i love the way it pulls with the sprocket on and its not coming up at the end of the gears just off the line i was having trouble. i was just wondering what everyone else was doing and if it was possible to leave the sprocket on.
timmyriv is offline
post #10 of 10 Old 04-12-2011, 10:34 AM
zx racer's Avatar
im lowered, strap, geared -1 +2 which is 16/41 and i weight 200 pounds. if its just coming up off the line try straping it down some more or slidin the forks down the tripple trees to see if that will help.
05 ZX-10R SWB.
zx racer is offline
Gen 2: Low End problem and Problem with Engine Solo-Six The ZX-10R 16 04-10-2011 12:53 AM
1/4 Gearing Help M109R Strip 22 02-16-2010 06:26 AM
Gearing ? M109R Strip 0 07-29-2009 06:02 PM
Gearing raulzx10r Performance and Tech 5 01-06-2007 06:04 PM
how will my 06 go with this gearing zedxten Performance and Tech 21 12-28-2006 01:32 AM
