fuel/tune question - Kawasaki ZX-10R.net
post #1 of 40 Old 11-02-2013, 01:54 PM Thread Starter
Blue08's Avatar
Location: Mentor on the Lake, Ohio/Broke at a dragstrip
fuel/tune question
im reading up on different fuels for my bike when I take it to the track. I have a brocks exhaust. pc3, ecu flashed and a few other bolt ons. this winter im putting in my kawi race cam, and thin head gasket and possibly a small shot of spray. once I finish im getting it tuned and my question is what would be a good fuel I was reading and it seems like mr12 is popular any specific fuel that would be good with that set up? and I believe id have to ditch the PC3 and get a pcv or bazzaz to run 2 different maps. one for the mr12 and one for 87 for the street? im completely stupid when it comes to all this fancy electrical stuff haha so throw me a bone please.
65, pos
8.67 @ 154mph
Blue08 is offline
post #2 of 40 Old 11-02-2013, 07:19 PM
gazx10's Avatar
used dynojet multi function hub can be purchased cheap and will allow 2 maps simply plugged into your pc3. mr12 requires a specific tune, throttle position mapping is by far the best way. expect power increases of 8-10 hp in midrange from 6k and 7-8 hp on top tuned properly. my torque increased almost 5 lbs. throttle response improved also. been running mr12 3 years now, it will be in my tank 3 days straight for the dragbike races this coming weekend as it has been for the last 3 years. I drain the tank, couple of gallons pump in tank, crank and idle till mr12 flushed thru system, about 3 minutes. no problems. opened shelf life less than 6 mos. and it is highly active in the metal storage can. basically nasty stuff to store due to expansion, contraction, and odor, siphoning and flushing is simple and quick. it's not much trouble at all for the performance increase it provides. just my experience. not a good fuel for nitrous though.
gazx10 is offline
post #3 of 40 Old 11-03-2013, 07:07 AM
Agreed^^^^ but make sure u only spray small shit on mr12 and tune needs to be on point. Also agree use the hub and if u want u can always add the ignition module that's how my bikes r set up
Sent from Motorcycle.com App
beanedisel is offline
post #4 of 40 Old 11-04-2013, 12:20 AM
matt d's Avatar
I have had the best luck with C85 from VP. I went quicker than MR12. Tested it back to back at the track. Ran MR12, drained it, then put the C85 in and went slightly faster, but not by too much. DA was the same on both passes as well.
68" 2011 ZX10
matt d is offline
post #5 of 40 Old 11-04-2013, 06:47 AM
What is c85 is it like the e85 ethanol/methanol or something never heard of it
post #6 of 40 Old 11-04-2013, 08:51 AM
Grease Monkey Bandit
AirborneMechanic's Avatar
Why not spray on mr12? Asking because op said he may be spraying and I'm in the same boat. What is good to spray on?
"Homewrecker" Gen3 custom build by ZX-SIK-R in progress.... check the build thread: https://www.zx-10r.net/forum/f28/airb...ad-140226.html
AirborneMechanic is offline
post #7 of 40 Old 11-04-2013, 08:59 AM
Slow Poke
bgmagma10's Avatar
You don't want to spray on MR12 because it's a low octane fuel. Usually 87-89 octane. Not safe for nitrous.
bgmagma10 is offline
post #8 of 40 Old 11-04-2013, 09:11 AM
We have guys that spray on mr12 but u have to be carefull because of the lie octane but if u pull a couple degrees of timing and spray only a baby shot it's fine I prefer to spray on the Q16 still has oxy and plenty of octane I know it's over kill on a small shot but it's really safe plus I didn't lose hp on motor like I do with the c16
post #9 of 40 Old 11-04-2013, 09:50 AM
That's how its done.
SelenaP is offline
post #10 of 40 Old 11-06-2013, 01:36 PM
zx-sik-r's Avatar
ACTUALLY if your considering spraying and running on motor I'd go with MRX02,it handles nitrous very well and no need to pull timing unless you go over a 50.Q16 and C16 are for very large amounts of nitrous.will absolutely kill hp unless you really need the high amount of octane. Not a lot of people will admit it but you can advance the timing on gas and make some serious power but this is more of a grudge application because the engine won't last very long.
I really don't understand the theory of spraying on MR12 and pulling timing to make up for it? That's completely defeating the purpose of what you want to achieve.use a good fuel like MRXO2 and a 50 shot...if you wanna take it easy on the bearings tune to 11.5 AF and 5.4x's all day long.tune at 12.2 and you could easily put the bike into the 5.3x mark if your a talented rider.
My gen 1 only made 200hp on a 50 shot and ran a 5.40 off the trailer every time I took it out,but I tuned it very fat to prolong bearing life.
2008 ZX-10r 68" Dime Piece BST wheels
Authorized Woolich Tuner - FLASHED BY SIK
zx-sik-r is offline
gen4 : best fuel for dyno tune Elite Performance and Tech 7 09-28-2013 07:22 AM
Gen 2: Horrible Fuel Mileage after TRE, PC3, and Dyno tune autoluxury The ZX-10R 30 05-11-2013 03:20 PM
Gen 1: PC tune question horsePOOGAS Performance and Tech 9 12-24-2012 03:36 PM
ECU tune question.. kwilliams14 Performance and Tech 4 09-30-2012 06:27 AM
WTB: Bazzaz Z-FI fuel management and auto tune Quantrill Wanted: Buy or Trade 2 11-23-2011 04:10 PM
