fuel alcohol pros and cons ? - Kawasaki ZX-10R.net
post #1 of 7 Old 05-25-2013, 12:28 PM Thread Starter
SPEEDFREAK776's Avatar
is anybody running alcohol at the drag strip in there zx10r what are the benefits
what are the cons just looking for a lil info
SPEEDFREAK776 is offline
post #2 of 7 Old 05-25-2013, 08:38 PM
gazx10's Avatar
not worth it without extensive engine, fuel system updates. u need very high compression ratio for alcohol to be efficient, special fuel seals throughout system, high flow injectors and pump. don guhl does some alcohol/methanol conversion work with bike engines, contact him. requires much more fuel volume, impractical except for racing only. not cheap$$$.
gazx10 is offline
post #3 of 7 Old 05-25-2013, 08:49 PM Thread Starter
thank you thats just what i was wanting to know dont sound like a very good option now knowing that info
post #4 of 7 Old 05-27-2013, 10:51 PM
matt d's Avatar
Run MR12 instead.
matt d is offline
post #5 of 7 Old 06-05-2013, 04:35 PM
tone.r's Avatar
one of my friends was running it and BBBBBOOOOOOOMMMMMMMM.:headshake
Tone.R {checkmate}
Do what makes u happy whatever it is.....Roberson Racing
tone.r is offline
post #6 of 7 Old 06-09-2013, 03:40 AM
Gamble_WRX's Avatar
I feel like it would be complex to do/tune on a bike, but water/meth injection, can allow you to put down identical numbers that you could on c16 race fuel. however, that might only equate to a few ponies on a bike, so probably not worth it unless your really trying to squeeze out every ounce. plus ive heard that running 87 apparantly makes more power on a bike, which still makes no sense to me.
"Contrary to popular belief, Drinking rum at 9 am, does not make you an alcoholic. It makes you a Pirate."
VOTE FOR BIGCAT!
Rides:
2005 Zx-10R Raw ti. Akra Slip on, Servo Delete, PCIII, CF sliders, and spools, Riflemans 1/5th, HBR Undertail, DB windscreen, Flush mount turns, Pitbull Steering Stabilizer.
1993 Honda Del Sol Si, HBE, SRI, Tein Coilovers. DD Status
2003 Subaru WRX Wagon, 5MT, Legacy GT gearset, Stock block. still needs alot of parts, and alot of work.
Gamble_WRX is offline
post #7 of 7 Old 06-09-2013, 10:13 AM
Speed Freak
garth285's Avatar
You should call up Guhl Motors, he does a TON of alcohol kits for 600s and 1000's The trick is you need a SHIT ton of furl pump and injectors but he says you can gain 2-3 times the power mr12 gives you.
garth285 is offline
Gen 2: Single sided swingarm pros/cons? knej29642 The ZX-10R 15 06-02-2012 02:16 PM
Pros and cons rwarner56 The ZX-10R 8 02-03-2012 10:24 AM
dumped exhaust pros/cons proelky The ZX-10R 30 09-17-2009 07:15 PM
Pros/Cons of 07 vs 08 Models NuckaMan The ZX-10R 52 08-05-2009 01:49 AM
Pros and cons of powder coating wheels maze The Out House 5 01-30-2006 01:18 PM
