First time at strip with the 10 - Kawasaki ZX-10R.net
post #1 of 19 Old 10-01-2011, 09:03 PM Thread Starter
gazx10's Avatar
finally made it to the strip for the first time with my 10 streetbike. temp in mid 70's and a 10-20 mph cross wind at track. track was also a little slippery, leaving a 6500 to hook and still breaking loose a little, shows in 60 fts. spun on the best mph pass. got great potential. have time slips but cant post tonight. first pass spun 1.66 60ft. 6.002 @121.68, 2nd pass hooked and had to feather throttle a little on first gear wheelie.1.489 60 ft. 5.89 @123.93, last pass spun 1.605 60 ft. 5.90 @124.86.
gazx10 is offline
post #2 of 19 Old 10-01-2011, 09:09 PM
bluedevil's Avatar
Originally Posted by gazx10 View Post
finally made it to the strip for the first time with my 10 streetbike. temp in mid 70's and a 10-20 mph cross wind at track. track was also a little slippery, leaving a 6500 to hook and still breaking loose a little, shows in 60 fts. spun on the best mph pass. got great potential. have time slips but cant post tonight. first pass spun 1.66 60ft. 6.002 @121.68, 2nd pass hooked and had to feather throttle a litte on first gear wheelie.1.489 60 ft. 5.89 @123.93, last pass spun 1.605 60 ft. 5.90 @124.86.
bluedevil is offline
post #3 of 19 Old 10-01-2011, 09:15 PM
Shift_Nashville's Avatar
Was that on swb??? Those are great times, but this is coming from someone who's not that great on the strip
i could give two shits if you were taking a bubble bath in applesauce being fed grapes by lemurs with electrodes attached to your nipples in the bed of a semi truck, as long as you're not holding up traffic, go for it
Shift_Nashville is offline
post #4 of 19 Old 10-01-2011, 09:28 PM Thread Starter
gazx10's Avatar
62 in., good rider. track was slippery, bike only event, about 60 bikes, no cars putting down fresh rubber, and unprepped as a private event. had to leave soft. rider did a good job today under conditions. gonna pull some high 1.30's, low 1.40's, make a couple of changes, and post some new times.
gazx10 is offline
post #5 of 19 Old 10-01-2011, 10:11 PM
BANNED
I was going to say damn swb.............., then saw it's at 62 inches
hellboytt is offline
post #6 of 19 Old 10-01-2011, 10:34 PM
zx racer's Avatar
nice times man
05 ZX-10R SWB.
zx racer is online now
post #7 of 19 Old 10-01-2011, 10:54 PM
bluedevil's Avatar
Did you read the part "1st Time on the 10" ...62in isn't that long I think it will only get better.
post #8 of 19 Old 10-01-2011, 11:15 PM
cookmaster30's Avatar
man thats a hell of a time for 62 inches. what do you weigh and what is done to the bikeif u dont mind
cookmaster30 is offline
post #9 of 19 Old 10-02-2011, 06:01 AM Thread Starter
gazx10's Avatar
thanks guys, bike is running strong, full street trim, ridden every day. track was the issue, not the rider, everybody was struggling, and we only got 3 first out passes. just swap the 60's which are terrible and we had 5.70's in hand. eng. mods are my headwork, small stk. lift web regrinds at 107-104, shimmed stk. valve springs, cnc full radius valve job, thin hg, ,015 deck to restore combustion chamber work done, tb flies, rods, and step removed, timing advanced 3 degrees mechanically, int. tract blended from stk. stacks to valves, k and n, tiforce ex., welded basket with stk. springs shimmed .080, pair plates connected, afr at 13.7. rider weight suited 175.
gazx10 is offline
post #10 of 19 Old 10-02-2011, 07:50 AM
Flipr's Avatar
And your only going to get quicker too!!
Area P slip-on & link pipe,De-catted Headers,PCV & Autotune,Ivans block off plates,K & N filter,X-Tre,Driven Superlite sprockets,+2 rear,stock front,520 conversion,V4 Speedohealer,Servo motor eliminator,Re-valved Ohlins damper,Spiegler front brake lines,Zero Gravity SR dark smoke screen,Stompgrip tank pads,ZX-6 rear cowl,and more to come.
Speed dosen't kill,it's the sudden stop!!!
Flipr is offline
Took the Ten to the strip for the first time strkd50 Strip 39 11-07-2009 09:54 PM
First time at the strip elninja_10r Pictures and Videos 1 09-22-2008 04:21 PM
First time @ strip w/06 10R FRC Z51 Strip 49 07-31-2008 10:42 PM
My first time at the strip... TheTruth21 Strip 10 10-07-2006 06:56 PM
1st time at the strip..... grunty-motor Race and Stunt 2 08-09-2005 01:59 PM
