Gen 4: 2011-2015 Finally went 9's! - Kawasaki ZX-10R.net
post #1 of 21 Old 03-08-2013, 01:48 PM Thread Starter
SteedaGT's Avatar
Finally went 9's!
I installed my new clutch Wednesday, put the bike on the trailer, and went to the 1/4 mile. It was very cold plus my back tire is still a stock bt-016 with 11k miles on it so traction was an issue.
My 1st two runs (not shown) were used to break in the clutch so they were very easy launches and just rolling into the throttle each gear.
My 3rd run I got a was a new pb for me and the bike felt great other than the minor traction issues after the 1/8th.
4th run was super sketchy as there was absolutely zero traction. A car had broke before my run and the track was being cleaned for a while before anything ran. There just wasn't any heat in the track and I should have known. New pb 60' though...
5th and 6th runs were finally into the 9's. I knew at the end of the 5th run that it was good. I just had the feeling. 6th run backed it up and actually went quicker so I was happy.
All in all, I know I still need the testicle mod so I am able to get my 60' times down first and foremost. I'm gaining more and more confidence with the bike being lowered and slightly stretched though. It's still coming up in 1st, but not nearly as bad as before.
Things I need to work on:
1. Gain more confidence in launching the bike.
2. Learn how to get my foot back on the shifter quicker. I hit the limiter in 1st twice because I couldn't get my foot back up. I'm going to lower the stock rearsets down to their "low" mounting holes and see if that helps.
3. Install a new back tire (already in the garage) for better traction after the 1/8th.
I forgot my gopro so no video :(
SteedaGT is offline
post #2 of 21 Old 03-08-2013, 02:04 PM
Slow Poke
bgmagma10's Avatar
Hell yeah congrats man!!!! That thing is gonna fly once you get your 60's down!
bgmagma10 is offline
post #3 of 21 Old 03-08-2013, 03:43 PM
zx racer's Avatar
congrats man i new you could do it wat clutch did you end up goin with ?
05 ZX-10R SWB.
zx racer is offline
post #4 of 21 Old 03-08-2013, 04:14 PM
tacp_daddy's Avatar
Congrats bro!
You'll get better with practice I'm sure, but fwiw if you don't have a QS installed yet, look at one with a thumb shifter so you don't have to worry so much about getting your foot in place to shift before reaching the limiter... And you can worry about other things ;)
1990 CR 125 - blow'd up
2005 SV1000s - sold
2012 ZX-10R - sold
1987 YZF600 Track-only death machine
tacp_daddy is offline
post #5 of 21 Old 03-08-2013, 04:55 PM
or10r's Avatar
NICE!! Congrats!
or10r is offline
post #6 of 21 Old 03-08-2013, 05:51 PM Thread Starter
SteedaGT's Avatar
The cycle concepts drag pack with the heavy duty springs. I replaced all frictiona and steels along with 6 springs. I have another 3 springs to put in that are even heavier for when the nitrous goes on.
Originally Posted by tacp_daddy View Post
Congrats bro!
I have an RL quickshifter on my foot. A thumb shifter would be soooo much better. I'm thinking about running it off the nitrous once that goes on. Unless there is an electronic one?
I'm hoping so. I weighed myself at 141 lbs fully geared including my helmet so I should be a strong contender once my balls grow.
Originally Posted by or10r View Post
NICE!! Congrats!
Thank you. You've gotta come out once.
SteedaGT is offline
post #7 of 21 Old 03-08-2013, 06:31 PM
zx racer's Avatar
nice choice ! goin on 2 yrs on my dragpak and she still hookin.
05 ZX-10R SWB.
zx racer is offline
post #8 of 21 Old 03-08-2013, 07:03 PM
PatrickG's Avatar
Images: 15
DAMN MAN>>> GOT EAT SOME FU#$N FOOD!!!!
2005 ZX-10R Akrapovic Ti Evo 2 w/CF LOR can, PC3 with custom map, Factory Pro velocity stacks
2009 ZX-10r Full Gen4 Brock's SS exhaust with CF 14" can, PC3, Secondary Butterflies Removed, Kawasaki Race Exhaust Cam, My Own TRE, Degreed Cams 109/108
2011 zx10r Lower'd 2" Frt & Rear, Stretched 8", Graves CF slipon, GUHL Flashed ECU
PatrickG is offline
post #9 of 21 Old 03-08-2013, 08:02 PM
SIgixxer80's Avatar
Good job man, keep it up and you'll be getting down there
SIgixxer80 is offline
post #10 of 21 Old 03-09-2013, 02:15 AM
tacp_daddy's Avatar
There sure are. Not sure about one for your current QS setup, but yes they do make electronic push button ones
http://www.translogicusa.com/powershifters.php
2005 SV1000s - sold
2012 ZX-10R - sold
*NWS* - It finally has finally happened , sunglasses are bigger than bikinis....: mr_honez Adult Content - Photos / Videos - N.W.S. 22 01-19-2009 06:44 PM
Finally did it!!! drgracr4044 Strip 17 04-05-2008 08:51 PM
Finally... 44 The ZX-10R 24 03-28-2006 08:50 AM
Finally did it..... Ground Zero Performance and Tech 12 07-19-2005 05:52 PM
Finally got one... El Diablo ZX-6R & ZX-6RR Archives 18 07-02-2005 01:53 AM
