Gen 1: 2004-2005 few quick questions - Kawasaki ZX-10R.net
post #1 of 4 Old 09-04-2014, 08:20 PM Thread Starter
Sharkysreef's Avatar
few quick questions
Here is the setup.
04 zx10
head shaved .006
.55 head gasket
08 race intake cam
carpenter 60 psi springs
gen 2 injectors
been thinking about doing the modded intake cam for the exhaust ... which year? or are they all the same? are they worth doing? or just run the stock exh. cam? Or will a stock 08 exh be good??
06 zx10, 2 tone, 1/5th throttle, -2/+3 sprockets, 9" extension, green chain, scorpio 2way alarm, Dynatek programmer, Gipro gear indicator, speedodrd corrector, removed secondary's, dual custom Yoshi's, K&N, 09 zx14 calipers, Galfer steel lines, servo eliminator, shorty adjustable levers, gas tank radar mount,DB screen, dual hid's, servo removed, servo eliminator, cat gutted. Valves adjusted.
Sharkysreef is offline
post #2 of 4 Old 09-07-2014, 08:57 AM Thread Starter
Wow No one?
post #3 of 4 Old 09-16-2014, 02:00 AM
Gen 1-3 are interchangeable I believe but hard to get now. I got my stock cams degreed
gen1_josh is offline
post #4 of 4 Old 09-23-2014, 08:51 AM
flashf3's Avatar
Are u running nitrous....60 psi is a lot if u r not running gas....you could've ran the gen 3 spring and retainers...the gen 3 retainers are better than the gen 1 ...that are proned to fail
Team TMP Performance
Flash's Speed & Customs, LLC
Certified Dynojet Tuning Center
flashf3 is offline
a few quick questions zx10r will General Motorcycle Discussions 1 04-12-2013 08:11 AM
3 quick questions and I know you have the answer pmason718 The ZX-10R 25 02-29-2012 02:22 PM
Gen 4: A Few Quick Random Questions Live-Fast The ZX-10R 26 06-28-2011 11:43 PM
quick 08 w/m4 questions jimZX10r The ZX-10R 9 05-04-2009 09:01 AM
Quick questions Va zx10r The ZX-10R 2 12-05-2006 04:57 PM
