Estimated ET/MPH 1/4 mile - Kawasaki ZX-10R.net
post #1 of 9 Old 08-15-2013, 07:16 PM Thread Starter
CL'SZX10's Avatar
Hey, fellas have a question? What type of times can I expect with the below mods. 04 zx10, 66" rider190lbs. Also Does these mod require routinely engine refresh?
R & R ENGINE
+2MM OR +3MM PISTON KIT
BORE & REPLATE CYLINDER
COMETIC HEAD GASKET
COMPLETE GASKET KIT
KIT INTAKE & EXHAUST CAMS
NEW ROD & MAIN BEARINGS
NEW ROD NUTS & BOLTS
COMPLETE CYLINDER HEAD PREP
HIGH PERFORMANCE VALVE SPRINGS
NEW VALVE GUIDE SEALS
CNC VALVE JOB
CUSTOM PORTING
ASSEMBLY AND SET SPRING PRESSURES
BILLET CAM CHAIN TENSIONER
BLUEPRINT AND ASSEMBLY
DYNO TUNE WITH CUSTOM FUEL & IGNITION MAP
Looking to have these mod done next year, just wanted to know an estimated E/T.
Thanks in advance for the help..
CL'SZX10 is offline
post #2 of 9 Old 08-15-2013, 07:26 PM
It's gonna depend on riding ability. Who does the head and the cam degree lots of factors come into play. If u ever play to spray I would only go two mil bore I would b willing to guess if someone like Jeff or cnc did the head n cam with a two mil tuned right with good chassis around 8.60s on motor maybe faster depending on circumstances
Sent from Motorcycle.com App
beanedisel is offline
post #3 of 9 Old 08-15-2013, 07:37 PM Thread Starter
CL'SZX10's Avatar
Thanks for the prompt reply, no intention on spraying since the old lady is funding these mods. Rather a motor bike instead of spray.
Head n cam will be done by the builder..wish Jeff was easily accessible,but I'm sure he has plenty of work.
Ill be satisfied with that type of times..
Thanks again beanedisel... Check ur PM.
CL'SZX10 is offline
post #4 of 9 Old 08-15-2013, 08:28 PM
If u never gonna spray I would build a 2x4or 3x4 all motor monster that's what I'm building soon but doin a 2x4 for nitrous
post #5 of 9 Old 08-16-2013, 08:12 AM
gazx10's Avatar
I would use different cam combination with those mods for max power.
gazx10 is offline
post #6 of 9 Old 08-16-2013, 09:39 AM Thread Starter
CL'SZX10's Avatar
Gotcha..
This engine mod process might be harder than I expected. Of course I wanna make sure I spend the money in the right area with the right combo. Doesn't help that internal engine combination far exceed my mechanical level of expertise..
CL'SZX10 is offline
post #7 of 9 Old 08-16-2013, 11:09 AM
gazx10's Avatar
correct engine component selection/ assembly/ tuning seperates the fast from the rest and resolves a lot of struggles. can be a hell of a expensive and hard process learning and figuring out what works. you're on the right track. good luck with your build.
gazx10 is offline
post #8 of 9 Old 08-16-2013, 11:52 AM
Well said ^^^^^
post #9 of 9 Old 08-17-2013, 11:02 AM
BOOSTED's Avatar
Subscribed!
2016 Ninja H2 - CANADAS Fastest 1/4 - 8.34 at 169mph - 208.4mph in the mile. Brocks Performance Stage 2 Package, MC Cycle works Intercooler, Full Polished Slash-Cut Exhaust, DNA Filter, PC5, Brocks Lowering Links, Brocks Front Strap Kit, BST Rim, Adams Performance Swingarm 7-11", Zero Gravity Corsa Windscreen, Evotech Radiator Guard, Evotech Fork Sliders, Yoshimura Tail Tidy
2011 ZX10R - SOLD
BOOSTED is offline
245 mph in the Mile - turbo Gen 2 ZX10 dsabat Race and Stunt 39 06-30-2011 09:35 AM
Gen 4: 150+ MPH 2011 ZX-10r 1/4 mile video garth285 Pictures and Videos 63 02-25-2011 05:15 PM
278 mph standing mile on a streetbike, Bill Warner dsabat Race and Stunt 23 02-24-2011 04:46 AM
mojave mile, march-6/the fastest mile in the west CHARLIEZX600 General Motorcycle Discussions 9 03-08-2010 11:40 PM
120 MPH in the 1/8 mile 1300hemibusa Race and Stunt 5 02-03-2006 05:15 PM
