Dyno Run Today - Kawasaki ZX-10R.net
post #1 of 5 Old 03-08-2013, 09:39 PM Thread Starter
Darmentle's Avatar
Dyno Run Today
So off the bottle 161HP on the bottle 191HP on 93 octane :). The only problem we had on there was on the first spray pull came up to 7200 Nos came on at 15% it did everything good. But when the guy started to slow the bike down to end the run he down shifted and bump the throttle and re activated the nos again not knowing it and it spayed again. I thought that once it cycles once its done but it works off the tps volts. So i am confused on what to do . Tomorrow is the drags should i just hit the switch to the nos sytem at the end off the track to shut it down ?
07 zx10
DDM Hid Kit 8k
K&N Air Filter
Velocity Turbo kit
Evil Swing Arm
Gen 3 Motor
PC3
Darmentle is offline
post #2 of 5 Old 03-08-2013, 10:11 PM
BigCat for Prez!
BigCat10R's Avatar
If it's set for the throttle then it shouldn't spray till its wide open. If that's the case then ull be fine not to turn it off as long as u don't blip it coming back to the pit
BigCat10R is offline
post #3 of 5 Old 03-08-2013, 10:24 PM
All show and all go 10r
JLG0987's Avatar
Whats the torque increase?
JLG0987 is offline
post #4 of 5 Old 03-08-2013, 10:59 PM Thread Starter
Darmentle's Avatar
Ill have them email the dyno sheets i forgot to grab it. and ill let you know torque.
07 zx10
DDM Hid Kit 8k
K&N Air Filter
Velocity Turbo kit
Evil Swing Arm
Gen 3 Motor
PC3
post #5 of 5 Old 03-10-2013, 07:22 PM
gazx10's Avatar
part of the programming of the mini is a step where u set the mini to completley start the nitrous activation again once off throttle as in a run and u let off, come back on, it will studder, delay, start at programmed %, whatever u set it up to do all over. the most common setup is once launched and thru the programmed steps, it hits full nitrous instantly when throttle rolled back and rolled on again and bypasses the program. key off or mini off, it resets for next pass. a blip of the throttle, dont know why he would do that, should not activate, only close to 90% wot. that's not a blip, that's nailing it. warned that u had mini tps wire hotwired full time when u tapped tps input wire and would trigger at set rpm regardless of throttle position. in ur case, sounds like that's exactly what happened. he exceeded 7200 on downshift and it sprayed as i stated it would. ck if tps activation working properly. set start spray rpm's at 0, key on, engine off, solenoid should come on only at 90% wot. if it doesnt activate there, u are not tps activating spray. other option, move wire to finger operated button, as in starter button or rig mechanical wot switch for it on tb linkage.
gazx10 is offline
Gen 4: Eurospec Dyno run today 177hp CDN1 The ZX-10R 12 02-20-2013 03:49 AM
Gen 1: Dyno run today. How bad is my a/f JBellZX10 Performance and Tech 23 05-01-2012 06:24 AM
Gen 3: Dyno Run Today gixxer160 Performance and Tech 4 04-04-2011 12:37 AM
Dyno run today after mods! Bently Performance and Tech 21 07-01-2006 02:06 PM
Did Dyno run today before the tear down Bently Performance and Tech 4 12-23-2005 09:05 AM
