Drop in the clamps - Kawasaki ZX-10R.net
post #1 of 23 Old 08-03-2009, 01:40 AM Thread Starter
Drop in the clamps
I would rather drop the forks in the triple clamps than strap it how far can I go before I hav issues with the fender hitting the bottom of the upper cowling?
Onequickzx10r is offline
post #2 of 23 Old 08-03-2009, 01:56 AM
Dont mess wit White Ninja
abzx10r's Avatar
I would say to you if your dropping your bike a good setup would be 1.5" or 2" flat with a 2" drop in the back and also push it out maybe a good 4-6" on the swing arm, gear it lower maybe 16/42 or 15/42 is what I run at the strip...But from your nose to the fender at 2" will have about a hole 1/4" or maybe just a little more. You wont be able to turn worth shit though so you know!!! Good luck!!!
abzx10r is offline
post #3 of 23 Old 08-05-2009, 08:14 PM
What wrong with strapping the front end ???
Wikid is offline
post #4 of 23 Old 08-05-2009, 09:16 PM
goldfish's Avatar
Just my opinion but I think guys strap the front instead of dropping them in the trees, because when the fork travel of an unstrapped fork would be way to much (Like close to 3") and when you wheelied or hit a bump it would smash the front fender into the front fairing. A problem you don't have with strapping the forks because you basically forced the forks to use all of there effective travel, thus they wouldn't be able to impact the front fairing. I would think you would want to get the springs cut down, rather then just dropping the trees. Just my , but I'm not a drag guy.
I never gave it to anyone that didn't deserve it...
goldfish is offline
post #5 of 23 Old 08-05-2009, 09:54 PM
nickalltogether's Avatar
Probably not far, only an inch or two.
2012 Kawasaki ZX-6R-Black
Clear Alternatives Tail Light
2005 Honda F4i-Red
Commuter stuff
2003 Yamaha Zuma-Fairy Silver
TPT 70cc Kit, Leo Vince ZX Exhaust, Malossi Delta Clutch, Scott's Damper Sticker
nickalltogether is offline
post #6 of 23 Old 08-05-2009, 09:58 PM
jblaze's Avatar
Images: 14
Pretty low! Lower than 2 inches. Never had a problem
http://pic19.picturetrail.com/VOL1085/3891346/21968035/368184613.jpg
jblaze is offline
post #7 of 23 Old 08-05-2009, 10:14 PM
^I can't believe that never hit the lower fairing! Did you remove your fork oil and fill it with concrete? My forks compress farther than that leaving the neighborhood.
2005 Honda F4i-Red
Commuter stuff
post #8 of 23 Old 08-05-2009, 10:25 PM
jblaze's Avatar
Images: 14
Nope, only time I hit the bottom is a pothole or a speed bump, but I pretty much try to avoid those. So scraping and rubbing isn't a problem for me as you can tell by my bottom fairing. Still have my fork oil, adjusted my suspension to not hop around as much as I would have it if it were to be stock height.
jblaze is offline
post #9 of 23 Old 08-05-2009, 10:25 PM
I guess it's just like lowered cars... You learn ways around obstacles.
2005 Honda F4i-Red
Commuter stuff
post #10 of 23 Old 08-05-2009, 10:27 PM
jblaze's Avatar
Images: 14
Exactamundo!
jblaze is offline
1'' drop gordotastic The ZX-10R 0 03-25-2009 09:23 AM
Attack Clamps Ben G Parts, Gear and Accessories 0 02-27-2009 07:14 AM
'06-'07 triple clamps silvrsled Parts, Gear and Accessories 1 09-07-2008 06:24 PM
Triple Clamps Mapless The ZX-10R 11 11-17-2005 08:18 PM
New Tripple Clamps :) flatout Vendors deals 96 11-13-2005 05:48 PM
