Drag strip gear ? - Kawasaki ZX-10R.net
post #1 of 11 Old 03-19-2008, 01:21 PM Thread Starter
OneSLOW10's Avatar
Send a message via AIM to OneSLOW10
Drag strip gear ?
Hey everyone. I always wear/wore full leathers when racing a motorcycle at the track.. I am just curious tho since the bottoms in the link i attached below looks like it would be good enough for those twisty track days what do you think about it on the drag strip? They look lilke they'd support you fairly well. Would they let you run with it on? Just curious b/c for the price I wouldn't mine getting a set and trying to see if they let me wear them.
http://www.motorcycle-superstore.com...Closeouts.aspx
2005 PMR. Full Ti Evo 2, BMC Race, V-Stacks, PC3, IG Module, DJ QS (not installed), 1/5th throw (not installed), -1 +2 with Gold RK Chain, Speedo Healer V4, Removed 2ndaries, Red GiPro, Pilot Powers, Dual H.I.D.s, Brocks brackets and strap, Rear 2" Muzzy Drop, Vortex Rearsets, Scotts Damper, 2 HyperPro Dampers, Puig DB, ASV Levers, Titax Levers, Pazzo Levers, Kill switch (made to look like it's mounted), CA front/rear lights and a owner who adores her...
OneSLOW10 is offline
post #2 of 11 Old 03-19-2008, 03:41 PM
Blink180Wilhelm's Avatar
Those are dirt bike pants dude. I am fairly certain no track would let you wear those. I know with the tracks in my area there are increasing restrictions with your times / the speed you go. Up here if you pass either 100 or 120 I can remember I think its 120 you need full leathers. If you are racing anything at the track Im gonna assume you will pass that mark. Save your money, buy leather.
How fast is too fast?
167.89 rwhp 2006 ZX-10R
Blink180Wilhelm is offline
post #3 of 11 Old 03-19-2008, 04:03 PM Thread Starter
OneSLOW10's Avatar
Thanks. I didn't realize they WERE dirt's. I figured they were modeled after dirt track gear but were twisty certified :)
Thanks.
post #4 of 11 Old 03-19-2008, 04:07 PM
Haha, no problem. At first I thought like you did, then realized it was just too good to be true and looked at the tabs that motorcyclesuperstore has.
post #5 of 11 Old 03-19-2008, 09:27 PM
bluedevil's Avatar
It's usually 120 mph you need FULL LEATHERS or a 2 piece that ZIPs into a 1 piece.
either way I have fairly thick leathers 1 piece and I donít even trust those because bottom line if you go down your not going to get lucky and maybe run off into some dirt, the walls are going to keep you on the concrete and itís going to hurt.
Most of the downs on the strip is at launch or at the end of the strip most likely due to OIL. If you go down on the end of the strip you could be doing 140mph plus so donít take the cheap route get some good leathers when you can.
bluedevil is offline
post #6 of 11 Old 03-19-2008, 09:38 PM Thread Starter
OneSLOW10's Avatar
opinion on this
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA:IT&ih=023
post #7 of 11 Old 03-19-2008, 09:45 PM
bluedevil's Avatar
Originally Posted by OneSLOW10 View Post
yeah if they zip together better than the one you where looking at...main thing is protection first(much better), then comfort and flex for better times. It should pass for any drag strip inspection
post #8 of 11 Old 03-19-2008, 09:57 PM Thread Starter
OneSLOW10's Avatar
just like the other dude said it was a over sight :)
we all have blonde moments :)
post #9 of 11 Old 03-19-2008, 10:01 PM
bluedevil's Avatar
lol...just don't have it on the drag strip with no gear.
post #10 of 11 Old 03-19-2008, 10:03 PM Thread Starter
OneSLOW10's Avatar
they'd kick ya off after your first pass anyhow. at least here they do..
one thing i always thought about was those drag vids on youtube where the guy goes up over the staging tree when he launches. i always though ugh i hope im not him :)
drag strip MAP needed tone.r Strip 4 11-07-2007 09:52 AM
Drag strip....... part II JodyH Race and Stunt 14 03-26-2006 07:09 PM
First drag strip run!! JodyH Race and Stunt 10 03-06-2006 07:11 AM
Drag Strip... Bobster Strip 28 05-31-2005 03:08 PM
We rented a drag strip!!!!! rocket10r Pictures and Videos 8 01-19-2005 03:40 PM
