Gen 3: 2008-2010 Does a Gen2 swingarm fit a Gen3?? YES IT DOES!!! - Kawasaki ZX-10R.net
post #1 of 18 Old 09-16-2011, 01:11 PM Thread Starter
PatrickG's Avatar
Images: 15
I'm dragracing my 09' zx10r and my wife also uses it when I'm not on it. But she still needed it lower for her to touch comfortably on the ground.
The problem with the Generation 3 swingarm is the upper bracing doesn't allow for it to be lowered very far. The shock reservior hit the bracing and the suspenion is stuck...
I have heard of a gen2 swingarm being used on other Generations so I figured I would try it out. The bracing for the Gen2 swingarm is all done below the swingarm so in theory it will allow for the bike to be lowered even farther.
I found a Gen2 swingarm off ebay for $40 shipped.. It has a few minor scraps but nothing else wrong with it.
I made some new lowering links for the bike a few weeks back when I tired to lower it and the shock stopped it from being any lower and had them ready to install.
I also took out the 9/16" 15mm spacer abover the upper shock mount also to lower the rearend somemore.
All told it worked out perfectly, no fitment or clearances issues whatsoever. The swingarm extentions that I bought worked on both Generations of swingarms.
ALTHOUGH!!!! The Generation 2 swingarm is shorter then the Generation 3 swingarm.
I know this because I used the same chain and everything, when I put the tire back on the chain was way too slack... I mean alot of slack. I'm glad I had about 1-1 1/2" of adjustability in my extentions otherwise I would have had to cut my new master link or find some larger sprockets. But it all worked out and the bike is the same length as it was before with the Gen3 swingarm installed.
So on a regular length bike, make sure you test fit the chain before riveting it together.
All the swingarm parts fit and swapped over without issue. I was able to use my generation 3 rear brake caliper setup. I don't know if you can do this without extentions, I mean reuse the caliper setup. U may have to buy a generation 2 brake setup for a stock wheelbase.
Otherwise it was well worth being able to lower it more. And the looks of it aren't bad either.
The bottom one is the Generation 3 before the swap.. U can see the adjusters are pushed farther back in the top few pictures.
Name:	swingarm swap1.jpg
ID:	153147   Click image for larger version
Name:	swingarm swap 2.jpg
ID:	153148   Click image for larger version
Name:	swingarm swap 3.jpg
ID:	153149   Click image for larger version
Name:	swingarm swap 4.jpg
ID:	153150   Click image for larger version
Name:	swingarm swap 9.jpg
2005 ZX-10R Akrapovic Ti Evo 2 w/CF LOR can, PC3 with custom map, Factory Pro velocity stacks
2009 ZX-10r Full Gen4 Brock's SS exhaust with CF 14" can, PC3, Secondary Butterflies Removed, Kawasaki Race Exhaust Cam, My Own TRE, Degreed Cams 109/108
2011 zx10r Lower'd 2" Frt & Rear, Stretched 8", Graves CF slipon, GUHL Flashed ECU
PatrickG is offline
post #2 of 18 Old 09-16-2011, 01:11 PM Thread Starter
PatrickG's Avatar
Images: 15
close up shots
Name:	swingarm swap 5.jpg
ID:	153151   Click image for larger version
Name:	swingarm swap 6.jpg
ID:	153152   Click image for larger version
Name:	swingarm swap 7.jpg
ID:	153153   Click image for larger version
Name:	swingarm swap 8.jpg
PatrickG is offline
post #3 of 18 Old 09-16-2011, 01:30 PM
ZXMAN6285's Avatar
usually not a fan of the extended swing arm bikes but that thing is sexy!
ZXMAN6285 is offline
post #4 of 18 Old 09-16-2011, 02:11 PM
RDLYN13000's Avatar
Images: 38
Looks good!! I'll give ya $50 shipped for your gen3 arm so you can make your money back!!
RDLYN13000 is offline
post #5 of 18 Old 09-16-2011, 08:55 PM Thread Starter
PatrickG's Avatar
Images: 15
It is slightly modified for dragracing and it has a slight ding on the right side where the previous owner must have dropped it on it and it hitting the factory exhaust can. The mod is that the brake tab that holds the brake caliper in place has been cut off this has to be done in order to run a 190 rear tire and have it extended up to about 5-6". Otherwise the tire rubs the brake tab and screws up the sidewall Don't know if u were serious or not. If so please pm me.
PatrickG is offline
post #6 of 18 Old 09-17-2011, 06:29 AM
RDLYN13000's Avatar
Images: 38
Thanks anyways, I'm not looking to extend
post #7 of 18 Old 09-17-2011, 09:49 PM
Gen2 Ripper
neverendingmods's Avatar
Gen2 arm is the best looking arm. Looks good man. Yeah, on the gen2 arm running extensions you have to grind away the rear brake tab on inside of arm. Once you do you can go back 8" . That's what I did atleast.
07-ZX10R-SOLD
, 1/5th insert, -1/+5,comp werkes decatted,PC3+multi-hub,piperX,30 dry shot,2custom maps,Ballistic EVO2,Pazzo shorties,SATO rearsets,HealTech,ZG Corsa,EBC XC Gen3 rotors,Vesrah pads, SS lines, Gen3 calipers, etc and stretched 8" so it won't flip
05-ZRX1200R-sold
04-KX500-sold
1975 RD350-garage queen
neverendingmods is offline
post #8 of 18 Old 09-17-2011, 09:55 PM
Gen2 Ripper
For those wondering, extensions designed for a gen2 arm come with the brake brace tab on them. At least the Myrtle West links do.
07-ZX10R-SOLD
05-ZRX1200R-sold
04-KX500-sold
post #9 of 18 Old 09-18-2011, 07:16 PM
Post Whore
1killer1liter's Avatar
Images: 11
Sounds like I'm better off keeping my gen1 arm and selling my gen3 arm due to clearance issues when lowered.
I live my life a quarter-pounder at a time. And for those 500 calories or more, im free. I need FRIESSSS! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didnt blow a seam on your nugget box.
1killer1liter is offline
post #10 of 18 Old 09-18-2011, 11:04 PM Thread Starter
PatrickG's Avatar
Images: 15
The Gen1 is built about the same in the shock reservior area so I'm not sure if it will be an issue for you or not. The Gen2 swingarm is perfect for taking it even lower though.
PatrickG is offline
Gen3 coils in a gen2 YES! TexasRider Performance and Tech 5 05-15-2011 07:21 AM
Gen2 and Gen3 Race / Suspension Manuals Solo-Six Performance and Tech 2 05-09-2011 11:34 AM
Gen 2: Gen3 Dash on a Gen2 Chuck Norris Performance and Tech 0 02-28-2011 03:56 AM
Gen3 to Gen2 Nutter34 The ZX-10R 7 12-01-2010 12:54 AM
gen3 wheels on gen2 edouble The ZX-10R 3 06-11-2010 06:26 PM
