Gen 2: 2006-2007 Critique this run - Kawasaki ZX-10R.net
post #1 of 12 Old 09-21-2011, 09:24 PM Thread Starter
Lycanthrope's Avatar
Critique this run
Running 6.80's (1/8) with 1.8 60 foot times, but I know she's a lot faster than that. Coming out at about 8000rpm, but I'm not sure if I have the throttle pinned at the light. Shifting at the stock shift light 11,500.
All stock save for -1 in the front.
Any obvious errors?
Lycanthrope is offline
post #2 of 12 Old 09-22-2011, 12:19 PM
zx racer's Avatar
your launching at the right rpm but need to get to WOT alot sooner. you can pick up a 1/5th throttle insert and it will help you get to wot alot sooner. its a member on here you can pm name rifleman who sells them if your interested in one.
05 ZX-10R SWB.
zx racer is offline
post #3 of 12 Old 09-22-2011, 10:47 PM Thread Starter
I already run that. Excellent addition.
post #4 of 12 Old 09-22-2011, 10:55 PM
bluedevil's Avatar
If your foot shifting 11.5k is wrong ring that sucker up to redline there is a delay your not as fast as a quick shifter.
And your not trully coming out at 8000rpms that is just what your gauge says that's just what RPM your holding...how much it goes down from there on the start is the key if SWB.
bloo
bluedevil is offline
post #5 of 12 Old 09-22-2011, 11:04 PM Thread Starter
Now that's information I can use. I was foot shifting and felt like I could give her more revs off the line. I tried 9K, but had some wheel spin, but think I could counter that with more burnout and perhaps dropping tire pressure. Been running about 26psi on a Q2.
post #6 of 12 Old 09-22-2011, 11:52 PM
NinjeR's Avatar
Gearing is a little high for the 1/8th with it being only -1 I believe. Tire pressure can go lower some. You do clutchless shifting? that''ll shave some time off. I guess practice if you don't plan on lowering and stretching.
Stock clutch with the slipper activating will slow you down also.
NinjeR is offline
post #7 of 12 Old 09-23-2011, 12:32 AM
BANNED
what is your mph? and are you stretched/straped/lowered? Your bike looks tame, mine always trying to lift the front in first gear and wonders around in second
It looks like you either have to slip the clutch little more, raise the rpms, go wot sooner and stage your bike on the either one of the tire grooves to get more traction.
hellboytt is offline
post #8 of 12 Old 09-23-2011, 02:17 AM
codyc_13's Avatar
I'm actually going to suggest the opposite, I would drop the rpms so you can get out of the clutch quicker and full throttle faster. Try 6500 and when you get to where your comfortable getting it pinned and getting the clutch out fast, start bumping the rpms up.
Sponsored by:
Vaughan Racing
Synthetic Shield
Moline Bar
codyc_13 is offline
post #9 of 12 Old 10-02-2011, 09:37 PM
WildB302's Avatar
especially with with your gearing and not lowered.
08 race cam(108/103), 08 retainers, polished exhaust ports, milled head(.010), .45HG, short velocity stacks, removed sec, bmc filter, full Akra Evo cut 5in, pc3., ign module w/rev xtend to 13,500., Lots of 520 sprckts, vortex rearsets (gp shift), pazzo levers, galfer lines, ZX14 calipers, shorai batt, carbon frnt fender, gpr, puig screen, gilles chain adjs., 1/5 throttle, Kleen air mod, Braking rotors, O.Z. wheels, 403lbs full fuel
http://www.youtube.com/user/TheWildb302/videos
WildB302 is offline
post #10 of 12 Old 10-03-2011, 11:40 AM
Slow Poke
bgmagma10's Avatar
I wouldn't. being that he's swb stock height. SLipping the clutch a lot further to keep your revs up will help more. If you leave lower and get the clutch out faster your going to bog worse. which may not show in your 60 ft but will definitely show in your 330 and 1/8th which will in turn show in your 1/4. You slip your clutch further your 60 may not be as good right off the bat but you will see improvement on the 330 and 1/8th mile..
bgmagma10 is offline
Forum Critique | Everyone please respond! hillcountry10r The Out House 90 10-07-2009 02:49 PM
Please critique my riding. 05pearlmagma10r Race and Stunt 90 05-04-2009 12:40 PM
Need Constructive Critique u Musicians! flapjak Pictures and Videos 15 11-30-2007 05:47 AM
Critique my form Hoser Pictures and Videos 19 05-26-2007 10:39 PM
