Clutchless Shifting Q - Kawasaki ZX-10R.net
post #1 of 20 Old 06-10-2008, 12:00 PM Thread Starter
OneSLOW10's Avatar
Send a message via AIM to OneSLOW10
I'm wanting to know once I get into 2nd if I just pop up thro the grears fast while WOT instead of backing off a tad and clutchin into the next gear if it will cause the front to pop up or get a little unstable. I will be straped and I don't have a DJ Quick Shifter or Air shifter yet so I just wanna see if its ok to bang the gears that way
2005 PMR. Full Ti Evo 2, BMC Race, V-Stacks, PC3, IG Module, DJ QS (not installed), 1/5th throw (not installed), -1 +2 with Gold RK Chain, Speedo Healer V4, Removed 2ndaries, Red GiPro, Pilot Powers, Dual H.I.D.s, Brocks brackets and strap, Rear 2" Muzzy Drop, Vortex Rearsets, Scotts Damper, 2 HyperPro Dampers, Puig DB, ASV Levers, Titax Levers, Pazzo Levers, Kill switch (made to look like it's mounted), CA front/rear lights and a owner who adores her...
OneSLOW10 is offline
post #2 of 20 Old 06-10-2008, 12:03 PM
logmaster's Avatar
expect a little front end shake if no damper. mine got a bit squirley on each shift.
logmaster is offline
post #3 of 20 Old 06-10-2008, 12:09 PM
SkyDork's Avatar
It's OK to upshift without the clutch, but you'll have to "back off" a tad anyways to get it to pop into the next gear. The gear dogs are undercut to help keep them together under load. The only way to allow them to disengage properly is to preload the shift pedal, back off the throttle slightly, and bang it into gear. It won't hurt anything if done properly. If done sloppily it can damage tranny parts such as forks, shift drum, gear dogs, etc. The quickshifter interupts the ignition signal when a gear change is made to allow the tranny to unload in this same fashion for a split second while the throttle is still held open.
If you've never done it before, I'd recommend practicing it outside of a dragstrip environment first.
It shouldn't cause the front end to wobble or come up unexpectedly when doing this.
#WordCrimes
SkyDork is offline
post #4 of 20 Old 06-10-2008, 12:17 PM
Post Whore
1killer1liter's Avatar
Images: 11
Look at the other thread you posted. I put up a vid of Norm Jackson and he is shifting without the clutch.
I live my life a quarter-pounder at a time. And for those 500 calories or more, im free. I need FRIESSSS! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didnt blow a seam on your nugget box.
1killer1liter is offline
post #5 of 20 Old 06-10-2008, 12:24 PM Thread Starter
OneSLOW10's Avatar
Thanks for the info. :)
post #6 of 20 Old 06-10-2008, 12:25 PM Thread Starter
OneSLOW10's Avatar
Will do brotha
post #7 of 20 Old 06-10-2008, 12:32 PM
redline659's Avatar
The dogs are not undercut on the zx-10 tranny stock..........
The ignition will also not kill when you pull up on the shifter.
redline659 is offline
post #8 of 20 Old 06-10-2008, 02:51 PM
Post Whore
Images: 11
With a DJ quickshifter it will.
post #9 of 20 Old 06-10-2008, 03:02 PM
inappropriate
hesaves0211's Avatar
Images: 67
please tell me you have a damper
1ST GEN-10R 234hp/[email protected], GT2871RS, cometic gasket, tial bov/ex wastegate, BEGI FMU, WALBRO fuel pump,falicon clutch basket,race pak clutch,200/50 pilot,yana-shiki levers,.net wristband, WEGO III,PC3,GPR damper,cbr cals/Galfer SS brake lines,gp shift,1/5 throttle, 2NDARIES REMOVED <<click for how-to, *R.I.P D.J 10 Apr 04*
hesaves0211 is offline
post #10 of 20 Old 06-10-2008, 04:36 PM
logmaster's Avatar
[QUOTE=SkyDork;965455]It's OK to upshift without the clutch, but you'll have to "back off" a tad anyways to get it to pop into the next gear. QUOTE]
You can hold WOT & slightly fan the clutch.........it wont let the revs drop that way.
I just got a damper. nice addition.
clutchless shifting jbl_91762 The ZX-10R 33 04-06-2007 12:19 AM
clutchless shifting EAST-LOS Performance and Tech 39 03-11-2007 08:08 AM
More Clutchless Shifting kawiman88 Performance and Tech 10 08-18-2006 01:38 PM
Can't seem to clutchless shift bragg10r Race and Stunt 32 01-29-2006 06:02 PM
Clutchless shifting cain772 The Out House 16 06-04-2005 02:23 AM
