Clutch Stack Height for Drag Racing - Kawasaki ZX-10R.net
post #1 of 3 Old 08-25-2010, 07:46 AM Thread Starter
mrbzx7's Avatar
Question Clutch Stack Height for Drag Racing
What stack height is everybody running, mine is close to the factory spec but my clutch grabs. I need it to slide a lil more so I can keep the rpms up. Plus it used to be 1.5's all day, now its stuck in the 1.6's range. I thought it was me but after three weeks I'm suspect of my clutch. I got some frictions and a couple thin steels, I want to see if I shorten the stack what will happen
mrbzx7 is offline
post #2 of 3 Old 08-25-2010, 10:30 AM
Send a message via AIM to Cycle Concepts
The stock oem stack height of 2.11'ish is fine..you can play with the clutch cable adjustment down on the clutch cover and the clutch perch to set or adjust the amount of clutch throw/pull to put the clutch engagement where you need it..having the clutch engage right off the grip can cause it to be grabby in a drag race situation..secondly, a common mod for the zx10's is to weld up the inner hub to disable the slipper clutch..I sell alot of my clutch paks to drag racers and these are some of the things that we discuss to help those guys get better performance out of their clutches..Feel free to give me a call if you have questions or need more help..803.285.8093
Cycle Concepts is offline
post #3 of 3 Old 08-25-2010, 11:16 AM
tone.r's Avatar
+1 cycle concepts drag-pak
Tone.R {checkmate}
Do what makes u happy whatever it is.....Roberson Racing
tone.r is offline
clutch stack height tone.r Performance and Tech 2 08-02-2010 12:02 PM
Clutch & Springs for drag racing M109R Strip 10 06-15-2010 08:10 PM
Drag Racing Clutch Kit 99vorsi Strip 12 03-26-2007 11:54 AM
best clutch kit for drag racing 99vorsi Strip 4 02-15-2007 11:03 AM
Drag racing Clutch set-up 06green Strip 27 12-11-2006 07:21 PM
