Clutch & Springs for drag racing - Kawasaki ZX-10R.net
post #1 of 11 Old 06-13-2010, 10:39 AM Thread Starter
M109R's Avatar
What are some of you guys running as far as clutches and springs go for racing. I am switching to Amsoil and gonna change clutch out. I had it out a while back and its showing the abuse sign. Also where is the best deal to get a clutch pack and springs.
M109R is offline
post #2 of 11 Old 06-13-2010, 02:16 PM
codyc_13's Avatar
Give Dwayne at concept cycles a call. His drag paks are top notch and CHEAP....
Sponsored by:
Vaughan Racing
Synthetic Shield
Moline Bar
codyc_13 is offline
post #3 of 11 Old 06-13-2010, 05:00 PM
drgracr4044's Avatar
i use OEM Kawasaki steels/fibers and Barnett 82 or 100 pound clutch springs(im not sure of actual rate, i just know theyre STIFF!!) just the stiffer springs alone dropped my 60' average from 1.67 to 1.61 or 1.62.
05 Green SWB
09 Special Edition. Muzzy GP series black teflon full system, Bazzaz Z-FI w/ AFM, K&N, fender elim.
drgracr4044 is offline
post #4 of 11 Old 06-13-2010, 05:09 PM
ZB10-R's Avatar
Send a message via AIM to ZB10-R
Where did you get the stiffer springs?
ZB10-R is offline
post #5 of 11 Old 06-13-2010, 05:32 PM
gbillzx10r's Avatar
Give Dwayne at concept cycles a call i hve been using his clutch for 2 years now and it is the best and he has stiffer springs too
NHRA # 286
2005 zx10r full muzzys system, lowered, stretched a few inchs, cycle concepts drag pak(the Best), air filter, sec. flies out, and a tune cycle-tek air shifter
gbillzx10r is offline
post #6 of 11 Old 06-13-2010, 05:47 PM
i contacted Barnett directly and spoke with one of their techs. explained what i was doing and how i wanted clutches to last a little longer and he sent me the springs. it took some getting used to launching it but it grabs much harder and quicker now.
05 Green SWB
post #7 of 11 Old 06-13-2010, 07:15 PM
tone.r's Avatar
YEP
Tone.R {checkmate}
Do what makes u happy whatever it is.....Roberson Racing
tone.r is offline
post #8 of 11 Old 06-13-2010, 07:51 PM Thread Starter
M109R's Avatar
I will Give Cycle Concepts a call Thanks
M109R is offline
post #9 of 11 Old 06-14-2010, 11:39 PM
clutch master's Avatar
Just know that Dwayne's clutch pack doesnt come with the "double" steel, not that you really need to replace that one. It almost never warps and yes I have his clutch pack in my drag bike.
The clutch is your friend
clutch master is offline
post #10 of 11 Old 06-15-2010, 04:05 AM Thread Starter
M109R's Avatar
What is the idea of the double steel?
M109R is offline
Barnett Clutch Springs redline659 Parts, Gear and Accessories 9 11-27-2009 11:09 AM
Drag Racing Clutch Kit 99vorsi Strip 12 03-26-2007 11:54 AM
best clutch kit for drag racing 99vorsi Strip 4 02-15-2007 11:03 AM
Drag racing Clutch set-up 06green Strip 27 12-11-2006 07:21 PM
drag racing clutch setup rated zx Performance and Tech 26 10-27-2005 08:42 AM
