clutch options - Kawasaki ZX-10R.net
post #1 of 10 Old 12-15-2013, 07:18 PM Thread Starter
clutch options
I was out at the test n tune on saturday night to try the bike out After the ecu flash exhaust and sprockets but half way down the 1/4 mile my clutch started to slip.
The bike doesnt even have 2000kms on it and has only previously had about 8 runs down the strip prior to these last 3 runs.
What are some better clutch options for the gen 4
menace is offline
post #2 of 10 Old 12-15-2013, 09:46 PM
You would find answers far quicker and more detailed by searching. Sorry to be that guy.
viasevenvai is offline
post #3 of 10 Old 12-15-2013, 10:11 PM
cooter's Avatar
No personal experience I'm still running the stock setup. From what I've read on here most guys like the OEM plates but upgrade the springs. Some also instal a clutch mod.
cooter is offline
post #4 of 10 Old 12-16-2013, 04:07 AM Thread Starter
My computer shit it self so im stuck using my phone. Unfortunately the search function doesnt work on the phone.
is they any recommendations on what springs to use.
Also what is the clutch mod
menace is offline
post #5 of 10 Old 12-16-2013, 07:21 AM
cooter's Avatar
Go to Brocks website they have spring kits, clutch mods and cushion kits. Just google Brocks Zx10r clutch.
It is my understanding that the clutch mod heavier springs and cushion kit work together to allow the clutch to grab better so it doesn't wear as fast on the hard launches. The clutch mod takes out the slipper clutch and allows you to add the stiffer springs. The springs push harder so you will feel it in the lever but they also push harder on the clutch too. I have no clue how the cushion kit works but I guess it extends the life of the clutch and helps it hook up better so you get better launches 60' mph and et's.
cooter is offline
post #6 of 10 Old 12-16-2013, 09:58 AM
zx racer's Avatar
get with dewayne at cycleconcepts he sells a dragpak that me and others on here has had alot of good luck with very cool guy with alot of knowledge.
05 ZX-10R SWB.
zx racer is offline
post #7 of 10 Old 12-20-2013, 04:15 AM
matt d's Avatar
Brock's Clutch Mod - $100
Brock's Clutch Cushion Kit - $200
APE Trac King clutch pack - $145
I go 1.3 60fts with this setup and high 8's in the 1/4, in the heat of summer.
68" 2011 ZX10
matt d is offline
post #8 of 10 Old 12-20-2013, 07:25 AM
cooter's Avatar
Is that set up still ok to run on the street?
cooter is offline
post #9 of 10 Old 12-21-2013, 01:24 AM
matt d's Avatar
Absolutely. I run my bike all the time on the street with it. The clutch mod disables the factory slipper clutch. It has no ill effect on street riding. The cushion kit with the springs does increase the stiffness of the clutch lever, but again, has no ill effect.
68" 2011 ZX10
matt d is offline
post #10 of 10 Old 12-30-2013, 01:42 PM
:mod_smilie_+1: cycleconcepts dragpak is the way to go
dragracer67 is offline
Gen 1: Seat options dude Performance and Tech 9 03-07-2012 08:41 AM
Gen 1: Gearing options Hobbe Performance and Tech 14 02-01-2012 03:22 AM
Gen 2: What are my options? Vortec The ZX-10R 18 10-10-2011 10:47 PM
Pipe options Daniel Patrick The ZX-10R 13 12-21-2006 02:04 PM
Jacket options ducatiwv The Out House 8 10-04-2005 09:36 PM
