Clutch issue - Kawasaki ZX-10R.net
post #1 of 14 Old 07-09-2010, 08:59 PM Thread Starter
M109R's Avatar
Clutch issue
Well guys put a new clutch in bike switched over to the motorcycle Amsoil 10w40 oil and after 9 runs i got slipping issues. Bike was working great got my 60's back with the set up but now 3rd thru 5th it is slipping. I used the clutch pack from Cycle Concept and 3 heavier springs. Anyone have any issues running a full Synthetic or Amsoil 10w40?
M109R is offline
post #2 of 14 Old 07-09-2010, 09:14 PM
bluedevil's Avatar
Is this your first time installing a Cycle concepts Clutch Pak? I run Motul 5100 have been for years. The thing I found from going CC is I have problems adjusting the clutch cable right must be a slight clutch pack height thing(even though they are suppose to be OEM and same height I ordered). I don't slip but can't adjust per Manuel I have to play with it some, it's been causing me to have issues with out of adjustment on the track. Also, the Clutch Pak never lasted as long as the OEM but then again I am more aggressive when I first went to the track on the 10...on my Second CC pak.
Your 60 maybe improving but it could be your going WOT faster than you thought because of slipping.
I would check the adjustment from basket to lever first.
bloo
bluedevil is offline
post #3 of 14 Old 07-09-2010, 09:20 PM Thread Starter
M109R's Avatar
I used a clutch pack from a 04-05 and also used 3 valve springs from a gsxr. That's what I was told to use and was told would work along with the Amsoil. 2 get Motul i have to mail order it. Yes it is the first time using this clutch as the stock one started to die off 60' were climbing so that's why i changed out. Yes i been adjusting the clutch but its slipping 3rd thru 5th when it's wot high rpm's
M109R is offline
post #4 of 14 Old 07-10-2010, 04:13 PM
tank zx10r's Avatar
Images: 52
put all gsxr valve springs in there and u should be fine unless u are spraying a nice size shot and its too much for the clutch to hold
R.I.P Shannon T. Hightower July 29, 1971 August 4, 2007
All Kawasakis aren't created equal
tank zx10r is offline
post #5 of 14 Old 07-10-2010, 05:19 PM
nczx-10r's Avatar
Yes I have, I loved the amsoil at first unbelieveble shifting bike seemed to run cooler all that good stuff.........BUT about every 2 thousand miles my clutch would go to slipping.
ITS BETTER TO BE HATED FOR WHAT YOU ARE...
THAN LOVED FOR WHAT YOUR NOT..................
nczx-10r is offline
post #6 of 14 Old 07-10-2010, 05:33 PM
drgracr4044's Avatar
ive heard good things about the Cycle Concepts clutch pack but i still use the factory Kawasaki OEM setup everytime i replace them. i can usually get 80-90 passes SWB out of OEM clutch parts and ive run Amzoil 10w40 since i bought the bike with no slipping issues. maybe there is a difference in stack height?
05 Green SWB
09 Special Edition. Muzzy GP series black teflon full system, Bazzaz Z-FI w/ AFM, K&N, fender elim.
drgracr4044 is offline
post #7 of 14 Old 07-10-2010, 05:43 PM
bluedevil's Avatar
I don't think there is a difference in stack height I took measurements and seems to be spot on. What I did notice between Cycles Pak is it comes with the Fibers that have the small pads Through out the Pak, Unlike OEM that uses the small Pad fibers ONLY on the Inside and Outside(Qty-2) the OEM ones use the Big Pad fibers in the Middle. I don't know it that makes a difference you can tell Cycle Concepts Paks are from Japan and OEM fibers just not EXACTLY like the OEM setup you get when your bike comes from the dealer.
bloo
post #8 of 14 Old 07-10-2010, 05:57 PM Thread Starter
M109R's Avatar
The only difference between the 04-05 setup and the 07 is 04-05 use what i think is called a jutter spring which to me just looks like 2 steels put together with a space between them. I was also told only to run 3 of the valve springs so i didn't break the clutch rod. I am hoping the clutch can be saved. Gonna drain amsoil out pull clutch and check it and probably go back to a conventional motorcycle oil ( no more synthetic ). I am not spraying bike and weight of rider is 200lbs suited
M109R is offline
post #9 of 14 Old 07-10-2010, 09:49 PM
clutch master's Avatar
Don't run fully synthetic oil, contributes to clutch slip, found that out early on in my drag racing venture. I use castrol synthetic blend with no issues.
The clutch is your friend
clutch master is offline
post #10 of 14 Old 07-10-2010, 10:19 PM Thread Starter
M109R's Avatar
I always wondered if the full synthetic motorcycle oil was a good idea for drag racing. I took the guys word that it was a good thing to use but i'm not so sure now. I am just going back to conventional motorcycle oil no more synthetic oil for me. I am just hoping that the clutch isn't fried and it was just the oil that is making it slip
M109R is offline
Clutch Issue DGA The ZX-10R 4 05-24-2010 03:31 PM
2006 zx 10r clutch issue Onebadcat The ZX-10R 1 01-29-2010 11:16 PM
clutch issue SOUN1 Performance and Tech 5 06-17-2008 08:41 AM
Clutch issue. naoki The ZX-10R 1 05-25-2007 06:56 PM
Another clutch issue! vane The ZX-10R 16 09-01-2004 08:00 PM
