clutch cover leak. - Kawasaki ZX-10R.net
post #1 of 7 Old 01-27-2013, 04:01 PM Thread Starter
mposey22's Avatar
clutch cover leak.
Ive been having probs with the clutch cover leaking. As we all do the cover comes off and on alot. Anyone have any tips on the gasket. Should i use some kind of sealant or just use it the way it is. What do any of u use? Thanks.
mposey22 is offline
post #2 of 7 Old 01-28-2013, 08:35 AM
zx racer's Avatar
you could use some black silicone sealant around the gasket to keep it from leaking. ive used this stuff and it works wonders.
05 ZX-10R SWB.
zx racer is offline
post #3 of 7 Old 01-31-2013, 12:15 PM
Pimp/Player
Ripped10R's Avatar
Check the cover real good for cracks, I had a leak and thought it was a gasket then found out it the cover had a hair line crack at one of the bolt areas
Ripped10R is offline
post #4 of 7 Old 01-31-2013, 12:19 PM
Slow Poke
bgmagma10's Avatar
And you know there is a tightening pattern too right? I have gone round and round with my damn clutch cover leaking.
bgmagma10 is offline
post #5 of 7 Old 02-02-2013, 06:41 PM
i had same problem now i use a thin coat of grey rtv and no leaks
beanedisel is offline
post #6 of 7 Old 02-02-2013, 08:54 PM
Servo's Eliminatus ;)
hellsrazor's Avatar
Images: 23
If you clean the cover side and the case side real good and make sure there is no cracks like ripped said, and follow the correct pattern for tightening and the right amount of torque, there should be no problems.
hellsrazor is offline
post #7 of 7 Old 02-02-2013, 10:51 PM
mrbzx7's Avatar
I use yamabond its a thin grey sealant made by yamaha it cost like 10 bucks a tube, but its great stuff its all I use. I used some black rtv from wal mart one time on some cases, an had to pull the motor back out and apart never again lol. I reused my cover gasket like 10 times before it gave me trouble.
Andrews Motorsports
2009 ZX10R aka "The General"
2008 ZX14R coming soon!
Paypal [email protected]
mrbzx7 is offline
Gen 2: Valve cover leak... nekolak The ZX-10R 10 10-23-2018 10:05 AM
Gen 1: Clutch cover & oil pan leak NOSZX10R327 The ZX-10R 6 09-03-2012 08:17 PM
Valve cover leak... 06blackpearl Performance and Tech 5 06-01-2012 06:50 PM
Oil leak by clutch cover!! I_RUN The ZX-10R 8 03-14-2011 10:09 AM
Leak, clutch cover appocalypse Performance and Tech 0 11-06-2006 06:04 AM
