chain n brake line length - Kawasaki ZX-10R.net
post #1 of 10 Old 04-22-2008, 04:47 PM Thread Starter
hollywood99's Avatar
hey guys....im stretching my '05 out 6in and goin +1 on the rear sprocket...was wondering if u knew how long of a chain id need and how long of a rear brakeline...
thx
im fast as lightning, so you betta getcho nike's bro
hollywood99 is offline
post #2 of 10 Old 04-22-2008, 04:51 PM
wpbzx-10's Avatar
Send a message via AIM to wpbzx-10
for the chain your best bet to get the 150 links and take out what u dont need. thats what i did.
wpbzx-10 is offline
post #3 of 10 Old 04-22-2008, 09:49 PM
redline659's Avatar
+1 this way when you decide to juice it and slap a hair dryer on it and stretch it a lil more you have the chain.
redline659 is offline
post #4 of 10 Old 04-22-2008, 10:03 PM
bluedevil's Avatar
come on, I know some of you stetchers must have some concrete #S....I.E with a 525 chain front sprocket(insert Front sprocket #s 'here') and back sprocket (insert back sprocket #s 'here') I used this amount of links(insert amount of links used 'here') and my brake line was this long stetched (insert how far back from SWB 'here') Now that's not to hard to remember or do is it? I'm a SWB guy only
BTW, anyone know how far a 520 with -1/+1 on a first Gen can stretch back with 120 links...that's standard by most factory chains you can buy in the stores in a box.
bluedevil is offline
post #5 of 10 Old 04-22-2008, 10:18 PM
PaSt's Avatar
so u stuck with ur 10r after all
PaSt is offline
post #6 of 10 Old 04-22-2008, 10:22 PM
Vince10R's Avatar
I was about 8 inches back with stock 17,39 gearing and I had 136 links in a 525. I would also order a 150 an cut it to the right length that way you definetly have enough. I have a 530 now. give dwayne at cycle concepts a call he can help you out with everything you need.
Vince10R is offline
post #7 of 10 Old 04-22-2008, 10:28 PM
bluedevil's Avatar
Good Info. Vince.....kinda a rough estimate of what those 120 links can do in the box and thats about half(4in stretched)...just a guess but I bet it's close.
post #8 of 10 Old 04-23-2008, 07:59 AM
Vince10R's Avatar
Blue go here http://www.gearingcommander.com/ load in the 04 zx-10. then in the custom box put your gearing in. then if you scroll down there is a chain geometry calculator. You will see that you can change the amount of links there. measure the distance from the center to center on your sprockets for the wheelbase you want to end up at. then just change the link # until you get the distance correct for the wheelbase your looking for.
Vince10R is offline
post #9 of 10 Old 10-22-2008, 08:34 PM
drag links?
Im looking to purchase some lowering links for the strip..anybody kno of any good brands out there..i still ride it on the street but i want something so i can slam it at the track any help would be appreaciated
Nox25 is offline
post #10 of 10 Old 10-23-2008, 10:04 AM
oops wrong post!
Nox25 is offline
Chain length with -1+2??? Blink180Wilhelm Performance and Tech 10 04-11-2008 10:43 AM
Chain, sprockets, rear brake line mlkx3 Vendors deals 6 02-16-2008 08:50 PM
Nissin caliper brake line length question Speedslave Performance and Tech 3 01-13-2008 09:15 PM
Rear brake line length Hoser The ZX-10R 4 02-19-2007 11:17 AM
chain length hollywood99 Performance and Tech 7 02-02-2007 10:14 AM
